Ducktail install question
It may be a lot of time and effort, but those good shocks come in millions of sizes and pressures...id bet you could find some thy would work for the right length and weight of this deck lid!
about 30 dollars with the pivot and a clip that holds it out of the way when closed. (you can just see on the pic about half way down)
964.511.551.00 rod for frunk £5
964.511.569.00 pivot £13
999.507.372.07 clip when shut £2
Thanks for the idea. I think im gonna buy this.
I ended up using on shock and it works good. Are there tricks to getting this thing centered? It's off about 5mm to the left. Kinda annoying actually. Thought about drilling the bracket holes larger to give me more adjustment, but don't really want to go that far.
Pics please!!
Shims! Make a bunch of thin (1/32) shims with holes drilled for the decklid and start adding them to one side or another. Rob & I spent an hour or so one day getting mine aligned just right.
