FS: 964 Carrera RS Shifter
--SOLD--
My 964 that I recently bought was shifting a little sloppy so I bought the parts to install the Carrera RS shifter. After pulling off the under-body panels I realized the car already had a nice aftermarket shifter, but that the previous owner didn't install it correctly. Basically the shift rod needed to be installed higher using the newer style bushings (964-424-028-00). This mod would be required if you have an early year car with the older style bushings to run the Carrera RS shifter, info here: https://rennlist.com/forums/964-foru...t-install.html.
After making that bushing modification my car shifted great so I don't have a need for the Carrera RS shifter I purchased and I'm outside the time-frame for a return. So the following parts are for sale:
1. Carrera RS Gear Shifter - 964-424-015-08
2. Carrera RS Shift Fork - 964-424-017-01
3. Plastic Sleeve for shifter (x4) - 999-924-002-40
4. Lower support rod - plastic cup bushings (x2) - 928-116-145-03
All parts are Porsche OEM that I purchased from Sunset Porsche. Shoot me a PM if interested.
Looking to get $170 shipped for everything.
Mike
Mike
