Help !!! SMOKE
Help !!! SMOKE
Hi all
Just wondered if anyone had had this problem.
When I drive my car and come to a stop, I get a puff of smoke from the exhaust .
My mechanic seems to think it could be the valve stem oil seals, however I thought I would seek fellow owners advice before allowing him to start working on my engine.
My car is a 1992 c4 with 105k
Any advice is welcome
Cheers Lee
Cheers Lee
hi lee is the smoke coming from the exhaust or can you see it in the mirror out of the rear tyre well if the latter it could be power steering fluid dripping on exhaust the only real way is a leak down test to know
Smoke from the exhaust means that your engine is burning oil, and oil in the cylinders can be due to a number of reasons.
I had the same problem, especially after driving at speed coming to a halt at a traffic light or something.
Worn valve guides is a known issue, and my engine had this problem on cylinder 5 and 6. I first tried to change the valve stem seals, but I could feel the valve stems rattle in their guides when prying with my finger. A top end overhaul did the trick.
Cheers,
Tore
Cheers,
Tore
Thanks guys,
I had the valve cover seals done last year as that's what we thought it was, it helped but it is definitely coming from the exhaust.
I did feel that it would need a top end rebuild Tore? But I may go with the valve stem seals first to see how we get on.
Cheers agin
Cheers agin
