964 Forum 1989-1994
Anyone else had this issue with their clocks?
Old 07-23-2015, 08:37 AM
Doms964TurboII
Doms964TurboII's Avatar
Default Anyone else had this issue with their clocks?
Looks like a very thin layer that could be brushed off, but in loath to do so incase it will make it worse.
Anyone had / dealt with this?
Many thanks
Old 07-23-2015, 08:54 AM
DobermanDad
DobermanDad's Avatar
Looks like you may ned to get a new face for that gauge. Hard to tell from the photo.
They are some aftermarket ones and OEM ones. Good time to change the color if you're gonna change it. FVD sells some pretty cool ones.
Strange though, was it in the sun or something a lot?
Old 07-23-2015, 09:45 AM
Doms964TurboII
No, it's been in dry storage for 7y undercover and underground.
Old 07-23-2015, 10:00 AM
DobermanDad
It's weird, can't tell if it's delaminating or something formed on it. Are you going to repair it yourself or send it out?
I've taking a few gauge's a part on my 964. Had to repair my odometer/tripometer. It's not really hard, but takes some patience to get the lens off. That's the hardest part.
Old 07-23-2015, 01:59 PM
justin-in-athens
justin-in-athens's Avatar
It is delaminating. I would not mess with it. It is a fairly common problem. North Hollywood Speedometer is your best bet. Curious on the cost if you get a quote as one of my cars is in a similar state.
Old 07-23-2015, 02:08 PM
pi5tolpete
pi5tolpete's Avatar
Default yup
Had it.
https://rennlist.com/forums/964-foru...h-gauge-3.html
I took the glass off and removed the plastic between the two glass halves. Then I used a toothpick and an exacto to remove the laminate from the lights. Good enough for me for now.
Old 07-23-2015, 07:40 PM
Moody blue
Moody blue's Avatar
I had the same issue , told that humidity helps cause this , I took off the face myself carefully and with modelling knife cut around lights (carefully) and the flaking part literally fell away. Took 1 hour and lights are now clear and a lot brighter , most wouldn't know to look at it , and I will eventually get all the gauges refaced.
Old 07-23-2015, 09:59 PM
Shamstar
Shamstar's Avatar
Contact Julian at Reap Automotive Design, he specialises in refurbing Porsche clocks and his work is second to none... It suits you as he's based in Harrow!
Old 07-28-2015, 06:46 AM
Doms964TurboII
Thanks everyone
Quick Reply: Anyone else had this issue with their clocks?
