964 Forum 1989-1994
964 VIN
Old 05-17-2015, 06:06 AM
kkswow12
kkswow12's Avatar
Default 964 VIN
is there a way to tell if a car is a 2 or a 4 from the VIN?
Old 05-17-2015, 11:36 AM
daniel94
daniel94's Avatar
What year is the car
Old 05-17-2015, 12:30 PM
kkswow12
kkswow12's Avatar
it is a 1991...
WPOZZZ96ZMS406458
a friend just told me that there is nothing to indicate 2 or 4 in the VIN...i was wondering, short of climbing under (there's an oxymoron for you) the car and just looking...
Old 05-17-2015, 12:40 PM
LPMM
LPMM's Avatar
Originally Posted by kkswow12
it is a 1991...
It would be easier to get a pic of the switch panel just forward of the shifter (1 switch on the C2 vs. 2 switches on the C4) or the rear brakes (2-piston on C2 vs. 4-piston on the C4)
Old 05-17-2015, 03:38 PM
kkswow12
kkswow12's Avatar
LPMM...good enough, thanks very much...
Old 05-18-2015, 11:53 AM
964George
964George's Avatar
Late C2's also had 4 pot rear calipers so not fool proof...
Easiest way is the diff lock dial on the centre console as advised earlier.
Plus you should get an all wheel drive warning light come on when turning the ignition, should go out once the engines started.
Another identifier is the ABS ECU in the frunk, C4's have a blue label as they also control the all wheel drive, C2's are a pinky coloured label.
Other than climbing underneath, that about it...
Old 05-18-2015, 01:14 PM
Harry Apps
Harry Apps's Avatar
Some have a "2" or "4" on the boot lid/engine cover.
See here too to download production numbers: http://www.adrianstreather.com/
Quick Reply: 964 VIN
