964 Forum 1989-1994
What did you do to or with you 964 today?
Old 08-29-2015, 06:27 PM
  #181
tdiquattro
tdiquattro's Avatar
de greaser and pressure wash, obviously I sealed up the intakes and oil connection first, and was careful where I pointed it lol.
Todays project was the exh manifold and oil return tubes...
Old 02-14-2016, 02:41 PM
  #182
tdiquattro
tdiquattro's Avatar
finished off sorting the inlet, changed from ally to plastic plenum, cut off brackets and removed the evap actuator. Re-positioned the vacuum reservoir to the rear of the engine bay and replaced/re-routed the vac lines and evap line to the rear as well. Re-routed the lower ignition leads behind the fan.
Can confirm all runs fine, I will make a bracket for the vac res, just temp for now to make sure it works.
Cut a chunk off the rear tin, don't see the point in it tbh, it just sits above the middle box and there is plenty of unguarded space either side so it is gone! I run a custom centre box anyway. few more holes here and there few more kilos saved
Dwerkz (02-12-2024)
Old 02-14-2016, 02:59 PM
  #183
bertsboat
bertsboat's Avatar
Drove it!
Old 02-15-2016, 09:19 PM
  #184
FeralComprehension
FeralComprehension's Avatar
Me too... in the snow.
Old 02-16-2016, 12:37 AM
  #185
Jjm4life
Jjm4life's Avatar
I didn't do it, but my g50/21 got opened up for a fresh gear set. Should be installed into my 964 around April.
Old 05-21-2016, 08:18 PM
  #186
Mr.Alex
Mr.Alex's Avatar
Spent a little too much time on ebay and got some LEDs to swap out. I didn't want to spend way to much money so I didn't go for the best of the best, but even then the difference is outstanding. Did the front turn signal, rear sidemarkers, rear brake bulbs, rear sidemarkers, and rear turn signals.
Old 05-22-2016, 12:06 AM
  #187
s4magman
s4magman's Avatar
Attachment 1053423
Attachment 1053424
Attachment 1053425
Attachment 1053426
Nicely done!
Old 05-23-2016, 08:22 PM
  #188
Nilo964
Nilo964's Avatar
Installed Bilstein HDs w H&R Sport springs, lowered to RoW stance. Ride is beautiful...firm and tight, yet comfortable. After owning it for 25 years, I love it more than the day I bought it.
Old 12-15-2016, 12:41 PM
  #189
911Jetta
911Jetta's Avatar
I just changed the oil. Fresh Brad Penn to take me through the winter.
It feels so good knowing there's new oil in the car.
Plus I added some extra good stuff. One can every six months.
I need to do a Blackstone oil analysis next time...
Quick Reply: What did you do to or with you 964 today?
