Sway bar identification help needed. TIA.
I have some sway bars that have been sitting in storage for some time and I don't remember what exactly they were.
The diameters from top to bottom are: 20.22, 21.29, 18.38, 22.36 with the 3rd being 3-way adjustable. My guess at least one rear and the front are original parts. Note that they were used on an RSA.
I will be listing them for sale as soon as I can identify them.
Thanks in advance for your insight.
The 3rd one, 3-way, is a CUP/RS swaybar, 18 mm. The two others for the rear would be an early C2, 21 mm or maybe M030 from RSA. The 20 mm one has a odd shape compared to the others so it maybe an aftermarket maybe? Even though the 20 mm diameter sounds sounds like stock. The front bar is thicker than stock as you say 22 mm so that is maybe a M030 from the RSA?
Thomas
Thomas
I don't recognize the top one but agree with Thomas about the other three.
The RSA 22 mm (M030) front bar should work nicely in conjunction with the 3 way adjustable RS (euro) rear bar. The 21 mm rear bar will be appealing to C4 owners who want to change their standard 18 mm rear bar.
