Whistle at 1,500 RPM. What should I check?
There is a plastic vacuum reservoir and a vacuum line connection on the backside of the airbox. If it sounds like an air whistle, and you think that it's coming from that area, I would put it on your checklist.
I had a similar sound which I could not locate.Finally traced it to a leak in a large oil tank breather line.
Line is about 3 ' long 1.25"diameter with a few bends. http://www.pelicanparts.com/catalog/..._pg2.htm#item8
