Diagnosis help
Diagnosis help
I recently experienced a unique issue at 4000 rpm I hear a rattle sound from the front of car, sounds like under dash area or floor board, but definitely at front of car. What's really odd is the clutch pedal does soft at the same time, to the point I have to pull it up 2 inches back to full extension. I'm baffled on what could be causing this issue. Any suggestion? Once I'm back below 3500 rpm the sound is gone. What could be causing the clutch pedal issue, isn't the system completely separate from the engine?
IHI KING!
The clutch pedal issue sounds like a faulty roll pin in the clutch pedal assembly. They are simple to fix and inexpensive.
Roll pin = https://rennlist.com/forums/964-foru...l-cluster.html
As for the rattle, does it happen in all gears at 4K rpm? Or just a specific speed? If its speed only, have you checked your tires for balance?
