964 Forum 1989-1994
Lightweight Battery
Old 03-08-2014, 02:16 PM
  #31
HiWind
HiWind's Avatar
I'm keen to help Stuart .... Ps the beauty of the vph750 is that it cuts itself off when running low so u never have to jump start...
And last 5-8 yrs.
Old 03-08-2014, 03:50 PM
  #32
STUARTQ
STUARTQ's Avatar
Originally Posted by evanscott964
Hi guys
I run a Super B lithium and thus far it has been perfect I tried a B10P but it just wasn't quite enough cranking power so got the B15P-SC. The biggest problem I found was trying to get a direct comparison of the stats no one seemed to be able to tell me which was which!!
Simon
Simon, do the super b batteries require anything other than charging off the alternator?
From what I've read they need a special mains charger but didn't see anything that mentioned car charging.
Old 03-08-2014, 07:10 PM
  #33
evanscott964
evanscott964's Avatar
Hi Stuart
Yes you do need a specific charger for the Lithium battery but the one I got was only £60 which is Super B also.
As previously mentioned once car is running amount of ancillaries is to a point irrelevant as alternator replaces what you take out. Key thing is stored charge for cold cranking on first start up, but I have a battery cut off for long non use periods!!
Simon
Old 04-23-2015, 02:49 PM
  #34
911Jetta
911Jetta's Avatar
WOW... 3 lb battery for >$200! Can't wait to lose 30 pounds (and I don't care if it's in the nose)
Originally Posted by 911Jetta
Thread from Pelican:
http://forums.pelicanparts.com/porsche-911-technical-forum/714823-who-street-legal-under-850kgs-1-875lbs-2.html
Steve says, "Want to take a lightweight battery to the next level?
Four ultra powerful A123 Systems lithium packs, originally developed for the Chevy Volt, used in the Fisker Karmas.
Total weight including case: 6.5 lbs. Power equivalent of a 60 lb lead acid battery." ...
OK that's still a bit complicated...
Jack Olsen keeps tinkering with the idea, and found this $200
...Lithium Iron Phosphate battery from Battery Tender for under $200.
It weighs less than 3-1/2 pounds.
Battery Tender LiFEPO4 battery
http://forums.pelicanparts.com/porsc...t-battery.html
Old 04-23-2015, 03:40 PM
  #35
JackOlsen
JackOlsen's Avatar
It's tiny. It looks like the Odyssey PC-680, but feels like they forgot to put any of the guts in it. Here it is in my smuggler's trunk.
Old 04-24-2015, 12:29 AM
  #36
hepkat63
hepkat63's Avatar
wow - more info (and pictures) please ! Looks great, does it work as you expected? Kind of lost on a 'smugglers box' too (thought these were only on pre 89 911 ?)
Old 04-24-2015, 12:50 AM
  #37
JackOlsen
JackOlsen's Avatar
My car is a '72. I did a longer writeup on the battery here.
No surprises so far. But I just got it this week.
Old 06-02-2015, 04:06 PM
  #38
911Jetta
911Jetta's Avatar
Even the 2 lb battery works well in a Boxster!
from Flatsixes.com
http://flatsixes.com/advise/advice-f...ght-batteries/
Old 06-02-2015, 05:23 PM
  #39
DobermanDad
DobermanDad's Avatar
I think I want to have one of these.
They work in a 964?
Old 06-02-2015, 06:42 PM
  #40
kos11-12
kos11-12's Avatar
yes perfect ,
nine is the same what is more important there is the CCA, its the power the bettery provide to start the car, the rest you only have to make sure everything is off when you crank the engine, so no dragging current to the battery
at 480 it is very good
Old 06-05-2015, 02:22 PM
  #41
HiWind
HiWind's Avatar
Thanks for the update Kos - keeping an eye on that options but it takes a long time to work out if a battery lasts
Old 06-05-2015, 03:12 PM
  #42
Streetdaddy
Streetdaddy's Avatar
I want one of these. Needs to be reliable... Maybe can use my heavy battery for winter time. That is a big weight saving.
Old 06-05-2015, 03:19 PM
  #43
breljohn
breljohn's Avatar
I got one. I'm not sure I will use it though as you have to cut the Porsche wiring to make your own.
Not sure I like that
Old 06-05-2015, 06:47 PM
  #44
Streetdaddy
Ahhh... Yeah , i don't like that either. Is there a lightweight that connect to regular terminals?
Old 06-05-2015, 06:55 PM
  #45
Streetdaddy
I read the article. He drilled thru some battery posts and secured them to the new battery.. Sounds like he used stock cables.
Quick Reply: Lightweight Battery
