964 Forum 1989-1994
How to remove headlight washer jet - nozzle?
Old 10-29-2012, 10:01 PM
Kuchar
Kuchar's Avatar
Default How to remove headlight washer jet - nozzle?
Please help ...
How to remove headlight washer jet - nozzle from bumper?
Do i have to remove front bumper? Or antifog light?
Who knows the best way?
Thank You, for Your help
Old 10-30-2012, 06:54 PM
Marc Shaw
Super Duper Moderator
Marc Shaw's Avatar
Removing the fog light won't help - best is to remove the front bumper. Takes 10 minutes, tops.
Marc
Old 11-01-2012, 11:17 AM
Kuchar
Kuchar's Avatar
Thank You, Marc.
Old 11-01-2012, 12:51 PM
stevepaa
stevepaa's Avatar
Why do you want to remove it? Or do you need to replace it?
Old 11-01-2012, 03:08 PM
Kuchar
Kuchar's Avatar
Yes jet is broken ... probably someone tried to steal it.
Old 11-27-2019, 10:24 PM
PASHN8
PASHN8's Avatar
Question following on from this. Car recently had a full respray and after I got the car home I filled the head lamp washer tank (via the filler neck, next to the petrol filler) and immediately both head lamp washers started dribbling water. This carried on for quite some time until the both stopped and the tank was empty. Water didn't leak from anywhere else, just out of the jets and a slow gravity style trickle. What do you think the problem is? Are there valves of some sort that haven't been refitted to both sides, or could the pump be at fault? This never happened to the respray.
Old 11-28-2019, 05:55 AM
Harry Apps
Harry Apps's Avatar
There appears to be one valve in the system. See PET illusstraion 904-20 item 6. Have you tried the washer itself?
Quick Reply: How to remove headlight washer jet - nozzle?
