Fuchs For 964...
#467
I don't imagine the car needs to run such aggressive camber to run the wheels. Just makes use of the space.
As per mine runs pretty aggressive set as favoured by Richie.
I believe he knows what he's doing but you'd need to contact Richie directly for his formular.
#468
If I am correct the car is running KWs from Richie at Milestone 71 as is mine.
#469
Hi Jcx.
Weirdly when I went from lowered springs to Richies set up I thought the car was totally different and waaay better!
I'm using a Clubsport wheel which i feel is too fat.
Be interested to drive a car with a different set up.
#470
Beauty of these cars; so (almost) infinitely adjustable. And 'feel' is such a personal thing. I now have 30' of camber on the front and 1degree (60') on the rear. This reduced offset (1 had a 1deg on the front before and 2 degs on the rear) makes the car much more agile and more adjustable on the brakes/throttle.
#471
from Facebook JZM
#472
RPM Tech
GOLD!
GOLD!
#476
Hi, Since 500Km I have a new set of 18" on my 964. As it need to be sitting a bit lower I'm leaning towards a set of 17" Fuchs.... would like to keep some comfort ;-)
I thin I will put this set online and order a 17" set when sold
The red one with gold fuchs are also 17" if I'm not mistaken?
#477
#478
