Sway bar/anti roll bar poly bush supplier in US?
I've been trying to find 20mm poly bushes for the front of my '90 C2 in the UK, but due to a fire at the Powerflex factory (one of the main suppliers here) There doesn't seem to be any available anywhere.
According to some distributors, they're could be a 6-9 month wait till they're back up and running... so my question is, can any of you Stateside Rennlisters recommend somewhere across the pond that I might be able to source some?
Cheers!
Cheers!
Design 911 list they have OEM, superpro poly and powerflex poly ARB bushes:
http://www.design911.co.uk/fu/pt385_...ll-Bar-Bushes/
However, I guess they will be out of the powerflex bushes because of what you say but maybe try the superpro version?
FWIW I fitted powerflex to mine and although they immediately sharpened up the chassis, I would say that it was more because the old bushes were worn out. I reckon that fitting new OEM bushes would have had pretty much the same effect as the more expensive powerflex bushes.
I was looking at the Superpro's, but they dont seem to do the 20mm version for the front ARB.
Might take your advice and fit a set of OEM's...
If you go for the OEM ones, Type 911 have them up on their on-line shop for £5 each! Must be a software glitch....get them while you can
http://www.type911shop.co.uk/shop/ca...aram=cid%3D%26
Guys,
We are the US distributor for Powerflex UK here in Virgina USA. We have 1 set of the 20mm swaybar bushings, PFFR57-209-20, for the 964 front or rear.
We also have a decent inventory of other 964/993/996 bushings as well.
PowerflexUSA.com
thanks,
Brian
PowerflexUSA.com
thanks,
Brian
