964 Forum 1989-1994
Brake slipping feel through pedal and ABS/warning lights on
Old 01-29-2010, 02:40 PM
darth
darth's Avatar
Dear Don
Do you have an volt/ohm meter and are you comfortable using it?
Bill
Old 01-30-2010, 03:31 PM
MA Shaw
Former Vendor
MA Shaw's Avatar
Yes I do.
-Don
Old 01-30-2010, 07:40 PM
darth
darth's Avatar
Dear Don
A simpler test than the one I suggested above is to measure the resistance of each speed sensor. The sensor is a coil of wire wrapped around an iron core. With the meter set on ohms, connect the 2 leads to the 2 contacts on the sensor connector. Select the lowest resistance range on the meter which still produces a reading. Any sensor that does not compare to the others in resistance may be suspect.
Bill
Quick Reply: Brake slipping feel through pedal and ABS/warning lights on
