964 Forum 1989-1994
BBS RS-GT with Hoosiers R6
Old 12-15-2006, 08:49 PM
David K.
David K.'s Avatar
Default BBS RS-GT with Hoosiers R6
New Never Used
BBS RS-GT Finish: Diamond Black w/Mach Lip
With New Mounted & Balance Hoosiers R6
8.5 x 18 56 mm offset
245/35/18 Hoosier R6
10 x 18 65 mm offset
285/30/18 Hoosier R6
Will fit 964, 993, 996, 944
Will Sell Rims with or without Hoosiers Tires
$4,100 Rims & Tires
$2,950 Rims Only
David
rsamerica@comcast.net
Old 12-15-2006, 10:19 PM
RajDatta
RajDatta's Avatar
You have a PM.
Raj
Old 12-16-2006, 12:25 AM
CWay27
CWay27's Avatar
Originally Posted by David K.
New Never Used
$4,100 Rims & Tires
$2,950 Rims Only
David
Wow 65 offset on a 10" wheel, I doubt it will fit 964. At least without spacers!!
good luck!!
Old 12-16-2006, 12:31 AM
JW in Texas
JW in Texas's Avatar
Yep, that's the offset my wheels were when I was running the RSA. I ran a stock 930 21mm spacer & just left them on the car all the time since all my rear wheels were the 65 offset. Worked great. Beautiful wheels by the way, Dave
Old 12-16-2006, 12:43 AM
CWay27
CWay27's Avatar
CUP wheels used the 21mm spacers and were also offset 65 but were 9.5 wide and not 10. Well it's good to know for the near futur.
Old 12-16-2006, 01:08 AM
JW in Texas
Yeah, 9.5s are ideal w/265s but 10s are plentiful & they will squeeze under there with the flat oil tube, rolled fenders & some camber. I ran 285s back there w/no problems. Really fills out the wheel wells
First is w/Fikses, 2nd is w/factory twists.
Man, I still miss that 'ol car
Old 12-16-2006, 01:16 AM
CWay27
CWay27's Avatar
Man, what a mean looking car with the fikse. Thanks for the info. I run 275 on CUP 9's with 47 offset.
Sorry David for highjacking your thead.......
Old 12-16-2006, 01:28 AM
JW in Texas
Me too Dave. Good luck with the sale!
Old 12-16-2006, 02:43 AM
parsecnc4
parsecnc4's Avatar
How would the wheels fit on a 965? Will it also need spacers since I believe 965 uses 17 x 7 ET55 fronts & 17 x 9 ET55 rears.
Old 12-16-2006, 10:24 AM
David K.
David K.'s Avatar
check the offset from the 965 3.6 turbo, they came with 18's.
Old 12-16-2006, 10:46 AM
David K.
David K.'s Avatar
Here's a shot of my car with my other set of BBS RS-GTs.
My car was the first car in the country to have a set, it was used by BBS as a display car.
I been tracking this set since 2002 (~125 DAYS), the wheel are still perfect, the
Diamond Black Finish is very tuff.
Keep in mind that the set of wheels & tires for sale are NEW NEVER USED.
David
Old 12-18-2006, 11:29 AM
cobalt
cobalt's Avatar
Received 1,937 Likes on 1,170 Posts
Dave,
You beat me to it. I was going to post the same picture. I have to admit that they do look stunning on your car. Why are you selling them?
I am sure Raj has already grabbed these but if not they will fit on a 965 with a small spacer in the rear. I was thinking about them myself but I have too many tires and rims as it is.
BTW did you resolve your exhaust issues?
Thanks for cutting me out of the picture.
Old 12-18-2006, 12:09 PM
David K.
David K.'s Avatar
Originally Posted by cobalt
Dave,
I pick up a 2nd set of RS-GTs at the end of August and had Hoosiers R6 mount up. Then my car went to Powertech's and $3,400 later (tuning, drive shafts, wheel bearing, rotors); I do not need both expense right now so I and selling the new set.
The wheels are still available. You can mount the Michelin PS2s on them that you got from my buddy Greg.
"Exhaust Issues", I just run open pipes. How did I sound at Porscherama?
Old 12-18-2006, 12:20 PM
cobalt
cobalt's Avatar
I think you were the loudest car there. You said you were loosing power from the open pipes and I thought you were making changes.
Too bad the PS2's are 17's and not 18's otherwise I would be all over them. These would work nicely on either the GTS or the turbo. Xmas has cost me too much and I just purchased sport seats for the turbo so if you are willing to sell them at a deep discount I must refrain or sell the 944.
Then again if I mount the PS2's on my spare set of 17" cup 1's I can possibly sell them for close to $2k putting me a third of the way there. The tires can always come later.
If I can swing it I will contact you.
Happy Holidays.
Old 12-18-2006, 12:28 PM
David K.
David K.'s Avatar
sell the 944.
Happy Holidays.
Below 4000 rpm the torque falls off compared to the Flowmaster & on the top end it only picks up 3 hp.
Sell the 944 and the cup 1's!
Quick Reply: BBS RS-GT with Hoosiers R6
