Headstuds too short?
Hi,
I'm using head studs 944-101-197-01 for the 89 944 with the 2.7L head. This is a 944S2 3.0L block. I'm not getting enough thread engagement. These are 150mm give or take.
I have a set of the S2 studs which I assume are for the 16V head, but they're about 20mm longer. That's about the length I may need here.
Real dumb question. I have the studs bottomed out. Before I change over to the longer studs, did I install these studs wrong? I ask because I'm almost positive these are the correct studs for this job. Yet, too short in this block.
The studs should not be bottomed out. The proper way to install them is to the height above deck as recommended in the workshop manual.
That said, they may still be too short. Hopefully someone else will chime in with the correct stud length and installation height for the 2.7 head and 3L block.
Install those studs to about 72mm above the deck and you should be good to go. No need to bottom them out, as long as you have plenty of thread engagement in the block at 72mm.
Well, even if back the studs out by a couple turns each, I'm not sure they'd be 72mm above the deck. That'd be backing them out by 6-8 turns. That would probably work, but doesn't seem right to me.
Is it generally a good idea to not bottom them out then? I wonder why, won't they bottom out when torqued anyway?
You need to put something on the stud to keep it from turning, so they won't bottom out. See thread from earlier this week....
https://rennlist.com/forums/944-turb...-question.html
Rainman
The studs shouldn't move much if at all when torquing the nuts - torque on the nut stretches the stud in place, it doesn't go like a bolt would.
Nothing worse than someone who doesn't update the thread. So I tried one of the S2 bolts but it was fantastically too long. Back to these 2.7L bolts. I had to back each out a little more than 4 turns to get the full 72mm sticking out. They work fine now.
I hope this isn't a significant reduction in threads. Sounds like it should be fine. But really 10mm longer would be more idea.
