Does this TPS plug/harness look normal? (pic)
went to change my TPS the other day and saw this when I unplugged the harness. Is there supposed to be a hole with a metal contact missing? (see pic below)
Also, any tips for getting to that pesky lower screw that holds the TPS? I'd rather not remove the throttle body...
Thanks!
Thanks!
That's normal.
Good luck with the screw. I would just pull the throttle body and rebuild it. Kit below comes with hex screws instead of phillips.
http://www.arnnworx.com/catalog/inde...38b785b4baec8a
