Which KLR pin carries the TPS variable signal?
I need to tap the variable signal from the TPS, do I take it off pin 22 or pin 23 of the KLR? I'm thinking I need the signal off tps pin 3, so klr pin 22 should be the right one? Thanks.
I saw this somewhere
TPS Plug Pin #1 to KLR Pin #21
TPS Plug Pin #2 to KLR Pin #23
TPS Plug Pin #3 to KLR Pin #22
TPS Plug Pin #4 to Ground
TPS Plug Pin #6 to DME Pin #7
This will be fed into a stand alone, if that matters.
One more question, which 2 pins ( I assume from the DME ) carry the 5 volt power and ground for the TPS? I need to make sure I wire up the TPS properly.
Nevermind, I realized KLR pin 23 carries the TPS ground and KLR pin 21 provides the TPS with its 5 volt supply.
