BMW 750 Master Cylinder w/BR brakes
Old 02-13-2012, 12:49 PM
bw993
bw993's Avatar
Default BMW 750 Master Cylinder w/BR brakes
Anyone using the 25mm master cylinder from a BMW 750 with their Big Red or Big Black conversion?
Did it improve the feel of the brake pedal?
Bill
Old 02-13-2012, 12:56 PM
Paulyy
Professional Hoon
Paulyy's Avatar
interesting..
Old 02-13-2012, 03:53 PM
333pg333
333pg333's Avatar
I'd do a search. Not being difficult, but I just can't remember who did it. I was going to put one in and bought one from Ebay, but never installed it. Be interesting to get some feedback though.
Old 02-14-2012, 12:04 AM
SSI Performance
Former Vendor
SSI Performance's Avatar
Default BMW 750 Brake Master Cylinder
Bill
After installing 928GTS Big Blacks on my 951 track car had low brake peddle I replaced every part including brake booster still had a low peddle. Heard about BMW 750 master installed it with Tilton brake bias works great.
The BMW 750 master cylinder only has two port one front & one rear so you will need to install a T fitting for the front brakes. If you are running ABS do not use adjustable brake bias ABS pump will damage bias valve. You will have to play with different size factory bias valves this will differ depending on weight of you car.
Sloan
Old 02-14-2012, 12:23 AM
SSI Performance
Former Vendor
BNW 750il brake master cylinder part number 34 31 1 156 643
Old 02-14-2012, 12:32 AM
David Floyd
David Floyd's Avatar
Sure would like to see a pic of it installed
Old 02-14-2012, 05:15 AM
Dubai944
Dubai944's Avatar
I used a BMW 750 master cylinder in my BMW 750...worked well in that application.
Old 02-14-2012, 07:19 AM
xschop
xschop's Avatar
What are the line port sizes/threads? Are they Bubble flared?
This would be another step forward in the V8 swap.
Old 02-14-2012, 07:42 AM
333pg333
333pg333's Avatar
I thought I had more pics on file. These are the only ones I have. Think there is 951 and 745 in there somewhere. Make of it what you will.
Pretty sure the 745 stuff is on the left and the 951 the right.
Old 02-14-2012, 10:58 AM
xschop
xschop's Avatar
That'll work. On the 944/951 the single front outlet goes to the rear brakes, Is the BMW the same? It looks like the Center-to-Center plate mount holes are a match. The only other unknown would be the pushrod interface depth, but that is easy to fix. Thanks for posting pics.
Old 02-14-2012, 11:14 AM
reno808
reno808's Avatar
LOL that was funny.
why not bore the 951 master cylinder
Old 02-14-2012, 12:29 PM
bw993
bw993's Avatar
Thanks for all the information. Looks like this is a bolt in for a 951 with ABS, since only one port is available for the front brakes (eliminates the need to plug the spare port on a 951 M/C). For a non-ABS car additional lines and a 3-tee connector are required, all of which I can buy from Porsche thru Pelican.
Bill
Old 02-14-2012, 12:32 PM
xschop
xschop's Avatar
Also the ports exit away from the driver's side head. That's the ticket on the V8 swap for a better non-boosted MC. The 944/951 MC mount holes are 60mm
C2C if anyone can confirm. It'll fit my adapter plate......
Old 02-14-2012, 12:40 PM
User 52121
User 52121's Avatar
Interesting.
I'm still running the stock calipers, etc. and *just* replaced my old M/C with a brand new one, and can't really complain now about pedal firmness - but wish I would've really dug into this sooner. I did some quick searches and most of what I found were just myths and rumors... "Hey I heard you can install a BMW master..." Etc. Glad to see some folks here finally posting up some REAL info (including an actual BMW part number!)
Way back in the day when I was into Shelby-Dodges I swapped in a M/C out of a full size Dodge truck into my Omni - pedal was rock hard - even without stainless lines. I *loved* that. Certainly confidence inspiring to have a very firm pedal.
Old 02-14-2012, 12:43 PM
Howellls2
Howellls2's Avatar
what's the red bar in the pick??
Quick Reply: BMW 750 Master Cylinder w/BR brakes
