wideband into smt6
wideband into smt6
i have an aem wideband and am trying to figure out which line the smt6 needs. the aem has 2 choices, use the 0-5V output or a serial output line. what does the smt6 need to see?
It's nice to have the temp connected to the temp sensor for warm up tuning purposes. So, I made a voltage divider using 1k and 4K precision resistors to convert the 0-5 output to a 0-1 volt signal, and then connected that to the narrow band input of the SMT6. With my zeitronix, it works remarkably well. I have to convert the output in my head (e.g., .22 volts equals exactly 11.8:1 with the zeitronix output) or log it and convert if via Excel, but it is spot on accurate. You just need to know the 0-5 output scale on your wideband so you can interpret the voltages. Here is Xeitronix's schematic for doing this:
http://www.zeitronix.com/Products/Zt...nt_setup.shtml
If you have a Zeitronix can't you use the simulated narrowband output to the 02 input on the SMT-6?
If I understood correctly that output should be pretty correct as it's simulated from the wideband signal?
I connected it that way but I'm not using it since I'm only logging with the Zeitronix.
/Dea
/Dea
/Dea
/Dea
I tried that, but was surprised to find that it only simulates the switch point -- i.e., it was essentially a binary output that would toggle between rich and lean based on whatever set point AFR you set in the zeitronix. I assume that's why they posted a schematic showing how to convert the 0-5v linear output to a 0-1v scale... Other wideband systems may have a true linear 0-1v output, but I've only used the zeit really.
What's the reason you've chosen to log with the SMT-6?
/Dea
The SMT6 also logs more signals (temp, MAF in and out, etc.)
Dea, I believe you have the newest PB Gray box. The software is different than what Tom has.
With the new unit, there is a cursor tracer function that highlights the cell in use making cell identification much simpler.
I have the tracer function -- thats why its so nice to have the piggyback log real afr's. You can step through the log and look at the actual afr you are getting on a cell by cell basis. Its just a nice convenience i think...
I stand corrected For some reason I was thinking you have the older unit...
What temp are you logging with the SMT-6, engine temp?
/Dea
I 'think' i have it. The active cell is highlighted in red and if i set the tracer it highlights all the cells it moved through in orange, so you can see its path. That's it, yes?
