Home Made MAF
http://cgi.ebay.com/ebaymotors/ws/eB...d=390122396648
Injectors
Chip/Piggy back
= done and done.
Injectors
Chip/Piggy back
= done and done.
Larger MAF generally means they can handle more before being maxed.
I wouldn't say there is any advantage of moving to a larger MAF so long as you aren't pegging your current one. In 99% of cases the MAF is going to be larger than any intake piping you've got so it won't be a restriction.
Large MAF's are definitely a pain to fit sometimes, especially in a blow-thru case where you want 6" of same length piping on both sides of the MAF before you step down to the smaller charge piping. I used to run a 70mm MAF in blow-thru on a turbo ford escort and it was a pain to fit the charge piping.
sorry
I have been reading all day im getting confused but im down to almost getting a cobra or lightning maf custom making the pipe and running an ostrich 2.0 with tunerpro software in a laptop. i hope this works.
jeez really i thought i could edit the maf code with the tuner pro. to put that maf in what essentially do i need an arc2? y am i getting the idea the ostrich and tuner pro is a good idea?
Small Business Partner
You most certainly can run a MAF. Will it be 100% correct (without changing the transfer function code), no but it will work.
-Rogue
tunerpro
I just DL'd tunerpro rt. I geuss thats the software i need for the ostrich. Do i need the booster cable thing they sell too. I feel like thats the way to go instead of constantly pgramming chips for ur mods. Found a website where you can buy a chip burner too so you can make your own.
-Rogue
