Manual rack - power tie rods - what's the answer?
I'm converting my turbo S over to manual steering. For those that aren't aware, the power racks use a different style of tie rod than the manual racks. Exactly why, I don't know - but one's a male thread and the other's a female thread...
My options were either to replace my perfectly good tie rods with new ones for the tune of about $350, or modify the steering rack... Option "B" was free.
So, I took the rack apart so I could get the bar out of it. Here's the manual bar (left) sitting next to a power bar:
Next step, in my lathe, to center drill a hole in the end:
After drilling, I was ready to tap it:
Here's the bar with the tapped holes:
And then it's over to the milling machine to make the locking notches. Job complete:
And it only took an hour or two.
I don't have pictures...
The manual rack comes apart very easily. The power one has a lot of pieces... the key is to undo the huge nut that holds the steel tube piece onto the aluminum housing piece. I put the rack in a vice and hammered away at that nut with a punch in one of the notches. Finally, just when I was about to give up, the nut started turning, and then it was a piece of cake after that.
Lazer Beam Shooter
I remember hearing something like a 914 tie rod end, or maybe an early 911 tie rod end would match up with the manual rack. anyone know anything about this?
http://www.paragon-products.com/prod...347.333.01.htm
Lemming, that's the other end - the spindle end. The issue with the manual vs power rack is the other end - the end that bolts up to the rack.
My understanding is that the early offset cars (including the '86 turbo) use the tie rod end that has the castle nut - and a male thread can only be used on manual steering tie rods.
The late offset cars use a tie rod end that does not have the castle nut, but rather a lock nut. I do not know if the tapers and lengths on the ball stud are the same...
Anyhow, the power steering tie rods have a female thread - and the rod its self is threaded with the male thread.
The real issue is the other end - the end that attaches to the rack.
Manual tie rod:
And power tie rod:
To sum up... Manual steering: rack end - tie rod ball socket has female threads; spindle end takes a ball joint that has a male thread.
Power steering: rack end - tie rod ball socket has male threads; spindle end take a ball joint that has a female thread.
I have late power tie rods; early power tie rods; and early manual tie rods in my possession - and have made my observations based on those.
Manual tie rod:
And power tie rod:
Van,
I was responding to Rock about the manual tie rod end (spindle). For a while Paragon was not selling the manual tie rod ends, just the inner and outer manual tire rod as one piece for $130/side.
When I was replacing hubs and spindles I needed to replace the outer tie rod ends on my manual rack since the boots were bad but I did not want to spend the money on the whole tie rod when the inners were just fine. I did some research and found that the early 911 tie rod end was the same as the 924/944 manual tire rod end and could be purchased without the inner tire rod. Paragon now sells just the outer manual tie rod. As you state that rod end will not work with your modified inner power steering rod.
Wish I had the machinery to do the work that you can in your shop. It's on my wish list, but my track car eats up all my cash
exact lengths
Did you measure the exact end to end lengths of both the manual and power rack rods (not tie-rods) end to end?
I am deciding which is the best route to go for adapting my bump steer kit to the manual rack since I've already done it for the Power rack and want to keep the inexpensive toyota tie rods that can be had for 40 bucks a pair.
Thanks, and definitely good work thinking out of the box....
BTW, the Toyota tie rods I sourced are M14 x 1.5
I assume that is the tap you used in the upper pic?
Basic Sponsor
We carry a tie rods for manual box and 951 chassis. No mods necessary.
Mike or Dave Lindsey
www.lindseyracing.com
U.S. 1-877-943-3565
Other 1-405-947-0137
U.S. 1-877-943-3565
