944 & 944S Forum 1982-1991
Need N/A clutch that can handle 300-350hp
Old 02-16-2017, 02:44 PM
hewitt330
hewitt330's Avatar
Default Need N/A clutch that can handle 300-350hp
What clutch upgrade options are available for an N/A Porsche. I'm turbocharging it and I need a clutch that can handle 300hp and probably 350-400 ft/lbs of torque without straining the clutch too much. I don't want to upgrade to the turbo clutch and have to buy a new flywheel, clutch, and bellhousing. That's way too much money and work. Lindsey racing makes spec clutches good for 500 ft/lbs of torque in n/a cars but they run about $1000 dollars. Is there any cheaper alternative. Like maybe a new oem pressure plate with an upgraded clutch disk, or maybe a centerforce clutch? I just want to know the cheapest way to get a clutch that can handle the power I'm looking for.
Sorry in advance for the wall of words.
Old 02-16-2017, 04:04 PM
V2Rocket
Rainman
V2Rocket's Avatar
Check out the Lindsey push-type clutch conversion, now available for NA.
Should be up to the task of what you want but you have to pay to play.
Quick Reply: Need N/A clutch that can handle 300-350hp
