ignition switch wires
Old 11-19-2007, 06:42 PM
laneskelton
laneskelton's Avatar
Default ignition switch wires
I am going to replace the ignition switch, but when I went to take the wires off the back plate came off and now I have no idea where the wires go. does anyone have a pic of the switch and which wires go where? Thanks
laneskelton is offline
Old 11-19-2007, 08:01 PM
laneskelton
bump
Old 11-19-2007, 10:59 PM
laneskelton
Or any knowledge of what wires go where?????
Old 11-19-2007, 11:19 PM
perrys4
The Lady's Man
perrys4's Avatar
I am planning on replacing mine Thursday so I hope someone comes to your aid since I will likley need it.
perrys4 is offline
Old 11-20-2007, 01:33 AM
j.kenzie@sbcglobal.net
j.kenzie@sbcglobal.net's Avatar
Lane,
This has come up before. Try search function. BTW when I changed mine, the wires were all attached by way of a big circular black connector. Did that burst apart and release all the wires? If so they should have a memory and you may be able to reconstruct the original configuration.
j.kenzie@sbcglobal.net is offline
Old 11-20-2007, 01:45 AM
Lizard928
Lizard928's Avatar
I may have that section of a wiring harness out in the garage, I will need to look tomorrow.
Lizard928 is offline
laneskelton
I searched for this and found others looking for answers, but none were given. The back piece up plastic came off releasing all the wires and I have no idea where they go.
Old 11-20-2007, 01:59 AM
Lizard928
Lizard928's Avatar
Alright I just ran out to the garage and took some shots for you.
I hope that they help/work for what you need.
This is from an 85, however should be the same for you car. HTH
Old 11-20-2007, 02:33 AM
laneskelton
Thanks Lizard, That should help me a ton.
Old 11-20-2007, 09:17 AM
Dennis Wilson
Dennis Wilson's Avatar
What a change! This happened to me 13 years ago (pre Rennlist) and the only advise I received from the PCA was "buy the workshop manual". It cost $425 and a lot of time to sort out the wiring. This makes the Rennlist membership the best bargain around.
Dennis
Dennis Wilson is offline
Old 11-20-2007, 09:38 AM
Alan
Electron Wrangler
Alan's Avatar
BTW - the wires that are the same colors are the same thing - the relative positions between these doesn't matter. They all connect together in the switch anyway.
This may help too https://rennlist.com/forums/showthre...eferrerid=6055
Alan
Alan is offline
Old 11-20-2007, 09:55 AM
Alan
Electron Wrangler
Alan's Avatar
For more detail: Terminal ID's should be marked on connector/switch body
Terminal 30 - 2(/3) x Reds are battery in (2 heavy duty(/1 thin))
Terminal 15 - 2 x Blacks are Ignition out (2 medium)
Terminal 50 - 1 x Yellow is Starter(relay) (thin)
Terminal X - 2 x Black/Yellows are Accessories (1 heavy & 1 med)
Terminal R - 1 x Red/Black is Radio Supply (medium)
Terminal P - Grey is Switch Off(0) Parking (thin-med)
Terminal 1 - Black/Red is key-in switch output (2 thin wires)
Terminal 2 - Red/Black(thin) is power in to key-in switch (thin)
Alan
Alan is offline
Old 11-20-2007, 11:43 AM
perrys4
The Lady's Man
perrys4's Avatar
Man, not sure if i want to do this now......electrical is not my bag. How do the wires fall off of that?
perrys4 is offline
Old 11-20-2007, 11:49 AM
Lizard928
Lizard928's Avatar
Perry if you look at pic 1 you can see that there is a cover on the back, it is held on by 3 clips. He managed to pop that cover off the back, then they fell out.
Old 11-20-2007, 03:21 PM
laneskelton
I got all the wires back where they belong, so now I'm just waiting for my new switch, and hopefully everything will go back together without anymore hitches. This website saves the day once again. Thanks again Lizard931
Quick Reply: ignition switch wires
