928 Forum 1978-1995
Sponsored by: 928 Specialists
Low fuel light only ever illuminates on Accessory key
Old 05-07-2017, 08:53 AM
95carrera
95carrera's Avatar
Default Low fuel light only ever illuminates on Accessory key
My low fuel light never comes on. I know bulb is working because when you turn key it comes on. When I bought car last year gauge was not working, turned out to be typical wear to ribbon electric thing. That was repaired. Reading at low fuel is sketchy so I watch trip odometer when I get close to 250 I get gas. Any ideas? Would like reserve light yo function correctly.
Old 05-07-2017, 10:30 AM
gazfish
gazfish's Avatar
What year, older cars have a third connection on the level sensor and grounding it should put the light on. I think later cars with a digital dash work on just the level to trigger the light.
Old 05-07-2017, 11:44 AM
Wisconsin Joe
Wisconsin Joe's Avatar
If you are only running it 250 miles, you aren't getting it low enough.
How much is the most fuel you've put in when it was "low"?
And I know what you mean about "sketchy" fuel gauge. Mine reads below 1/4 fairly soon, but will only take 15 or 16 gals when it's down almost to the empty line. And keep in mind that the bottom part of the gauge is pretty tight. From full to 3/4 is almost as far as from 3/4 to E.
I didn't think mine worked either. Until it did. Was way low on fuel when it came on (! light comes on too). Drove another 30 miles and put in less than 20 gals (nominal cap is 23).
Old 05-07-2017, 01:58 PM
SeanR
SeanR's Avatar
When the light comes on you will have approx 4 gallons of fuel left and it will take close to 18 gallons to fill. How much are you putting in at 250 miles?
Old 05-07-2017, 04:27 PM
95carrera
95carrera's Avatar
i ran it out of gas testing light. Coasted into station I think there was about 260 on it at the Time.
Old 05-07-2017, 04:40 PM
SeanR
SeanR's Avatar
How many gallons of gas did you put in? That was the important question. If you are only getting 260 miles out of a tank, your car is not running properly.
There is a way to test the sender, here are a couple of links.
https://rennlist.com/forums/928-foru...nt-w-pics.html
https://rennlist.com/forums/928-foru...-question.html
https://rennlist.com/forums/928-foru...ge-wiring.html
Hope those help.
Old 05-07-2017, 05:30 PM
95carrera
95carrera's Avatar
Gauge is working mostly. I drive it pretty hard. It does have Porken chips. I need to try getting it down to bottom again. I have put 20 or more gallons in with out light coming on.
So here is the real question: exactly what triggers the light? The needle location on gauge? If so that connection may be bad.
Old 05-07-2017, 05:36 PM
SeanR
SeanR's Avatar
Ok, that tells me you are able to fill the tank up properly. The light should trigger around the 4 gallon left in the tank and the light is triggered by the float in the sender when it gets to a certain point. You may either have a broken wire in the connector, bad sender or some wire busted along the loom to the gauges. The fact that your gauge light works with the key on unstarted tells me that it's at the back of the car.
You can pull the sensor out (after you've run the tank down) and take it apart and you might possibly be able to fix the issue. Sadly they are no longer available new from Porsche. Not yet anyway.
Old 05-07-2017, 08:44 PM
95carrera
95carrera's Avatar
Thanks. When I bought car last June it did not read at all. I pulled sending unit, cleaned it up and nothing. When you say sensor, are you referring to something other than the cylinder sending unit? I took it to shop and they pulled the pod and I think sent it off somewhere to repair ribbon? Not sure really.
Old 05-07-2017, 10:28 PM
SeanR
SeanR's Avatar
Yep, the sender in the tank. Top of the tank.
Old 05-07-2017, 11:36 PM
95carrera
95carrera's Avatar
So I need to check this yellow wire apparently?
Old 05-10-2017, 10:01 PM
95carrera
95carrera's Avatar
Default Update with Photos
244 miles
Filled the tank with 19 gallons so I had two gallons to go (approx)
Acc position to light dash, full tank. That's as high as needle goes.
Is this consistent with other S3 experiences?
Old 05-11-2017, 12:54 AM
The Forgotten On
The Forgotten On's Avatar
Needle is working better than most. A lot of them read 1/4 tank low.
Quick Reply: Low fuel light only ever illuminates on Accessory key
