928 Forum 1978-1995
Sponsored by: 928 Specialists
Need tips and advice! First car: 85' 928S
Old 02-19-2017, 12:09 AM
Z727
Z727's Avatar
Default --
Old 02-19-2017, 12:19 AM
SwedeInSiam
SwedeInSiam's Avatar
welcome to the craziness of 928 ownership.
You can't use only water. You need to have some corrosion inhibitor otherwise corrosion will eat up you engine from inside. My car as run with only water (sadly normal in Thailand) by PO and have some bad pittings in it.
If you have original fuel lines then change all the rubber parts before you drive the car. Mine looked perfect when I bought the car but when I bent them slightly the rubber just cracked and split the hose in two. Tropical climate isn't nice to rubber.
Old 02-19-2017, 12:27 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,255 Likes on 1,248 Posts
Hi Zie welcome this is a great place to get the assistance your going to need to fix that beauty .
First a few things before you try to fix anything.
You would be well served by reading the FAQ at the top of the page,
It takes about 4 days,
but it will answer a lot of your questions and give you guidance on where to look.
Become a paying member, 18.00 a yr,
and then you can have some other benefits like buying and selling parts for your car plus posting pictures.
Anyway good luck with your new project
Oh the air cleaner being upside down is the least of your troubles.
Old 02-19-2017, 05:52 PM
Kiwi'79
Kiwi'79's Avatar
G'day Zie and welcome!!
Great first post and even better first car!!
Plenty to do but that's part of the fun.
Coolant raises the freezing point (crucial where I live!!) and LOWERS the boiling point (crucial where you live!) along with lots of other goodies like rust inhibitors etc... you need it, no, your engine needs it
Somewhere along the lines your car appears to have been towed using the cross brace, that "stretch" has to come from somewhere, so check your bolts/mounts when you replace or repair it. You of course will know, this is NOT the place to tow your car.
Further to Stans comment regarding your air cleaner element, it will have to remain as it is now, until you replace it, otherwise all of the crud will get sucked into your intake when you flip it, I would not trust using compressed air as being sufficient enough to blow it all out either (Apologies if is obvious to you, but better I say it methinks).
Anyway, read, learn, and enjoy!!!
Old 02-19-2017, 07:20 PM
Wisconsin Joe
Wisconsin Joe's Avatar
First off, welcome. You've found the best place and the nicest people when it comes to these cars.
Anything you need to know can be found here. Some of it by searching, the rest by asking.
The seat switches are known to go bad. You can fix them, there's a really nice "how to" here:
https://rennlist.com/forums/964-foru...lace-them.html
There is a little allen bolt under the front of the seat. Use an allen wrench (also known as a "Hex Key") to turn it to move the seat forward and back. It drives a plastic gear, so be gentle. The gear is also missing a tooth to allow the motor to move the seat without turning the gear all the time, so it will 'skip', you may think it is stripping. It's supposed to do it some, but not a lot (again, it's a plastic gear, be gentle).
You can also remove the plastic cover and reverse the wires going into the center motor (there are three). That will allow the seat to go forwards when you push the switch to go "back".
Doing the seat switches is a lot easier if you take the seats out. Run the seat all the way forward to reach the bolts in the back, all the way back for the ones in the front.
While you are in there, you can clean up and lube the jackscrews that move the seat forwards & back.
Window switches are also pretty common failure points.
Replacements are available, or you can fix those too:
http://members.rennlist.com/v1uhoh/windowSW.htm
As was noted, read the "New Visitor" sticky. It has a ton of useful info.
Old 02-26-2017, 07:58 AM
Z928328
Z928328's Avatar
welcome my friend...
Old 02-26-2017, 12:53 PM
928NOOBIE
928NOOBIE's Avatar
pretty car..like the color. Congratulations.
Old 02-26-2017, 10:47 PM
polecat702
Vegas, Baby!
polecat702's Avatar
Welcome, and it's a great first car!
Is there a hole in the hood, or it that a reflection of something else?
Old 02-26-2017, 11:59 PM
SeanR
SeanR's Avatar
Great looking car man. Listen to Stan and you won't go wrong.
Old 02-27-2017, 10:33 AM
<'///<'s Avatar
Did Porsche produce some 1985 models with the 4.7? I thought they all had the 5 liter 32 valve.
Old 02-27-2017, 11:33 AM
Wisconsin Joe
The ROW (Rest of World) got the "S2" from 84-86. 4.7 16v.
US (and Canada) got the "S3" in 85 & 86. 5.0 32v.
The 5.0 was also available in some markets (Australia?)
Old 02-27-2017, 12:53 PM
hwyengr
hwyengr's Avatar
Switzerland and Japan got the 5.0 in '86, and the Aussie version was lower compression due to a lack of readily available high-octane gas.
Old 02-27-2017, 02:49 PM
Wisconsin Joe
That's it. Thank you.
The 4.7 M28/11 & 12 had high compression (10.4:1) and required high octane fuel.
Old 02-27-2017, 05:20 PM
Randy V
Randy V's Avatar
Looks like he's just another hit-and-run poster.
Old 02-27-2017, 07:40 PM
James Bailey
James Bailey's Avatar
The thought of owning and caring for a 928 in Brunie boggles the mind.....They got their one and only Porsche dealer in 1997 !!!! Basically means none of the techs were ever trained on the 928.
Quick Reply: Need tips and advice! First car: 85' 928S
