Rear suspension assembly question
I am reassembling on the car my rear suspension on my 1981 928 after a complete drive train overhaul.
Q. on the main lower control arm, where it attaches to the body, the forward eccentric bolt has a large eccentric disc on the front side. The disc is beveled on one side- does the bevel face toward the body or away from it ? (toward the nut).
Also, what is recommended lubricant, if any on the bushings that are in the forward and lower (to subframe) attachment points? I did not remove bushings from the arm.
What about on the metal bevelled washers on both sides of the upper link arm?
thanks, Mark
thanks, Mark
Basic Site Sponsor
Basic Site Sponsor
thanks, Mark
thanks, Mark
Dry.
Cup faces nut...away from arm.
