Fuel pump stays on as soon as I open the switch
#31
[QUOTE=hr928;13547930] .........If you where going to bypass the relay...where would you get the power from?? .........../QUOTE]
My suggestion is to loosen the bolts keeping the CE Panel vertical and lean it forward. I bet you will find your jumper wires on the backside.
Ask me how I know
Ask me how I know
#32
[QUOTE=hessank;13560299]
How do you know? LOL....I was hoping you be right cause I'm anxious to solve this problem, but I didn't find anything....then again I'm not sure what I'm looking for!
Going thru Alan's WD write up, and looking at the WD, I traced the power cable color Red with Green line to U plug top right pin (I read somewhere there's a numerical way of saying it, but I can't find it now). I pulled the plug and it looks ok, I pulled the CE Panel as you suggested and I cannot really tell if there's a jumper cable to that plug. Although I did noticed that board doesn't look like it's been removed in the past. The bolts were super tight without any evidence of a screw driver messing in there. Oh well....lots of more reading and research to do. If any of you see something out of sequence please raise your hand...need help!
#33
Guys I've not been able resolve my fuel-pump-all-the-time-on problem. If I disconnect the FP relay the FP comes on when I turn the key. I disconnected the LH and the FP still comes on. Only when I disconnect the U-Plug from the board that's when the FP doesn't come on.
#35
