928 Forum 1978-1995
Sponsored by: 928 Specialists
New Manual Shifter Design
Old 02-07-2017, 03:12 PM
  #76
hans14914
hans14914's Avatar
With several 928 racers showing interest in the front pivot clamp, I decided to give it a final tweak. Some racers prefer taller than stock levers to keep the shift **** up near the steering wheel. This puts considerably more leverage and stress on the bearing. I had minor concern that the standard bearing I selected for the stock and shorter height applications may not be sufficient for our racing brethren yanking long leavers with furious determination.
So, I located some affordable double-row sealed bearings and modified the bearing housing part to accept them. This does slightly increase the overall front-to-back depth of the bearing housings a small amount. The bearing fits within the original footprint, but the head of the shoulder bolt will protrude 3mm farther forward (towards the nose of the car) than the original design.
What this means for everyone is a stronger bearing housing. Stronger bearing, and higher precision shoulder bolt.
Here is what the new bearing housing looks like. It uses a standard M10-30-14.3mm double-row sealed bearing. Its a good thing I didin't order the bearings this past weekend.
Old 02-07-2017, 08:09 PM
  #77
RFJ
RFJ's Avatar
sounds very good to me,i think this will be a blast.It should give you the ability to shift like the old days. I love it.
Old 02-17-2017, 12:44 PM
  #78
hans14914
hans14914's Avatar
Making progress.
Machine shop just forwarded some pictures of shifter parts. Looks like they will be on to anodizing next week. I am still also waiting for the bushings to come in from Igus, so think everything will arrive about the same time.
I ordered extra bushings so I can try using them in the pivot clamp as an alternative to the dual race ball-bearing.
Old 02-17-2017, 01:03 PM
  #79
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,072 Likes on 1,183 Posts
Looks like this weekend is a great time to start pulling the TT and Trans from my 79!!
Those parts looks spectacular!!!
Old 02-17-2017, 07:19 PM
  #80
ReDesign by FEATHER
Basic Sponsor
ReDesign by FEATHER's Avatar
Hans, what are the cross section dimensions of the shift stick? They look thicker than the originals in your pictures.
ReDesign by FEATHER
by Jerry Feather
Producer for 928 of:
-Hatch Latch Receiver Liner--All Versions
-Replacement Heavy Duty Spare Tire Cover
-Flush Center Console Conversion
-Cowl Cover, Cowl Seal, & Shell Stickers--All versions
(RHD included)
-Aluminum Gas Cap Ratcheting Pawl
Old 02-20-2017, 11:56 AM
  #81
hans14914
hans14914's Avatar
I don't have the in my hands yet, but the models called for 7mm at that shifter attachment point, and 13mm at the fastener area.
It doesn't look like they can be anodized by the shop, so going to have to take them over to a local outfit this week when they arrive.
UPS says they should be here on Wednesday.
Old 02-20-2017, 12:37 PM
  #82
Jerry Feather
Jerry Feather's Avatar
Thanks Hans. I am looking for the width and thickness of the shaft in the top area where the leather covered rubber **** fits. I am thinking of making a mold to replicate the rubber ***** and need to know how big to make the shaft hole for these and/or for the originals, some of which I have. I'm wondering if they are the same or different cross section wise. 7mm thickness is the same, but how about width?
Old 02-20-2017, 01:09 PM
  #83
hans14914
hans14914's Avatar
Get with me off list. I already have a model for the standard ****, and was planning on making a GTS replica with a weighted insert for improved shift feel. I may be able to save you a couple steps.
Old 02-20-2017, 01:19 PM
  #84
Jerry Feather
PM sent.
Old 02-21-2017, 12:08 PM
  #85
hans14914
hans14914's Avatar
Just and update, parts will be here in Indy on Friday. I will have to get them anodized locally, which should not be an issue, we have four shops in town.
Bushings still have not shipped from Igus yet. I will give them a call tomorrow if they have not shipped yet. I am guessing they did not have 100 on-hand here in the states, but will see if they will do a partial order shipment.
Old 02-24-2017, 04:14 PM
  #86
hans14914
hans14914's Avatar
Lever machined parts came in today, and I have already whisked them off to the local anodizer for a bath. They should come back a pleasant satin clear by next Wednesday.
The bushings from Igus has shipped and they should be here on Monday.
I ordered some 13mm spacers for a total increase in pivot throw of 9mm which equates to a 36% decrease in shifter travel (at stock height). I figure that is a pretty good starting spacer, but McMaster stocks them in just about any length a person could ask for.
I will be eagerly testing this out on my GTS on Wednesday, and will report to the group how it feels in aluminum.
Old 02-24-2017, 04:23 PM
  #87
hacker-pschorr
Old 02-27-2017, 10:57 AM
  #88
hans14914
hans14914's Avatar
If anyone is curious what $300 of shifter bushings looks like, it comes in a 5x8" bag and weights 0.134lbs!
That's roughly $150/oz...
Expensive buggers, but these are the best bushings you can get for this application: Igus Z-series
Old 02-27-2017, 11:14 PM
  #89
RFJ
RFJ's Avatar
So Hans where are we? soon,I know you can't rush them but i am having trouble waiting. not much you understand you do understand right? understand arg having trouble you got it? no big deal just a little trouble, my hands keep grabbing for something that's not there but no trouble,AARRRGGGG.
Old 02-28-2017, 05:25 PM
  #90
hans14914
hans14914's Avatar
Parts came back from the anodizer. I have the first lever assembled with the 9mm of offset from original spacing. I will get it installed tonight and drive in tomorrow and report back.
Quick Reply: New Manual Shifter Design
