928 Forum 1978-1995
Sponsored by: 928 Specialists
Engine sucked Oil into intake manifold ,, Frantic please Help
Old 07-25-2016, 03:47 PM
Mark Thornton
Mark Thornton's Avatar
Default Engine sucked Oil into intake manifold ,, Frantic please Help
I was Driving my car and it started pouring smoke from the exhaust I removed the intake manifolds and found about a half pint of engine oil inside .. What could be the cause?? Need some help here folks. 1985 Porsche 928S
Old 07-25-2016, 03:54 PM
Ducman82
Ducman82's Avatar
what year car? oil in the intake is a common enough issue (blow by etc), but i have never seen so much get in the intake that it smoked out the exhaust. i would pull the plugs and check them.
Old 07-25-2016, 04:48 PM
davek9
davek9's Avatar
A little history will help on your '85, as I usually will find about a 1/2 fluid ounce per side a year (in the side plenums).
1/2 pint is excessive and exactly where was the oil located?
Old 07-25-2016, 06:33 PM
zekgb
zekgb's Avatar
Not sure if they fail all that often, but a missing or failed oil filler check valve would suck a crapload of oil into the intake.
Old 07-25-2016, 06:40 PM
Mark Thornton
Wow Where would I look for that ? I found oil in both plenums most of it was in the drivers side
Old 07-25-2016, 06:50 PM
zekgb
zekgb's Avatar
It's in the end of the hose that connects to the base of the oil filler neck.
Old 07-25-2016, 07:50 PM
ThetaTau87
ThetaTau87's Avatar
Over filling the sump with oil and/or long left hand turns can allow the PCV vents on the top of the RH cam cover to suck oil into the intake in quantities large enough to create thick smoke out the exhaust and even stall the engine.
Old 07-26-2016, 02:06 PM
WallyP
Rennlist Site Sponsor
WallyP's Avatar
Perhaps a more complete description of "I was Driving my car..." might give us some clues...
Old 07-26-2016, 11:43 PM
Daniel5691
Daniel5691's Avatar
Mark,
Any more updates?
Old 07-27-2016, 12:00 AM
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
To be clear, it has to be a bitchin hard and long left turn...
Old 07-27-2016, 01:17 AM
ThetaTau87
ThetaTau87's Avatar
Exactly like Swamp turn at Waterford Hill.
Old 07-27-2016, 10:41 AM
Mark Thornton
OK I was driving it pretty hard..and making right turns.. also the engine temp went up to last mark before the red zone. I am presently waiting for the weather to cool down it is just too hot to try to work in 100 deg heat.
Quick Reply: Engine sucked Oil into intake manifold ,, Frantic please Help
