928 Forum 1978-1995
Sponsored by: 928 Specialists
Need Pod Cores for a business start-up
Old 07-14-2016, 12:27 PM
Kevin in Atlanta
Kevin in Atlanta's Avatar
Default Need Pod Cores for a business start-up
I am giving serious consideration to starting a Pod and Dash restoration service.
Here's an example of a 91 pod that came off a car in Nevada.
Before with body filler (fiberglas version):
After:
(looks better in person without the glare) Not the truck bed liner painted version. :-)
Old 07-14-2016, 01:34 PM
Jadz928
Jadz928's Avatar
Good stuff!
Just some friendly advice... drill larger holes at the end of the stress-cracks to relieve the stress.
Wish you well with your venture.
Old 07-14-2016, 01:36 PM
Michael Benno
Michael Benno's Avatar
Originally Posted by Kevin in Atlanta
I am giving serious consideration to starting a Pod and Dash restoration service. Here's an example of a 91 pod that came off a car in Nevada. Before with body filler (fiberglas version): After: (looks better in person without the glare) Not the truck bed liner painted version. :-)
Looks good I have a dash pod I can donate in trade for some dash work if you are interested
Old 07-14-2016, 01:39 PM
Kevin in Atlanta
Originally Posted by Jadz928
Good stuff!
Good advice. Thanks.
Old 07-14-2016, 01:40 PM
Kevin in Atlanta
Very interested. PM to discuss.
Old 07-14-2016, 02:23 PM
davek9
davek9's Avatar
Have you done any testing how it will hold up under Heat (sun) and cooling cycles?
That seems to be the killer and why I've always chosen to just do a complete recover, I must say, that one does look great in the pic
Dave
Old 07-14-2016, 02:59 PM
Kevin in Atlanta
Dave
It is sitting a closed car in the direct GA sunlight right now. I will offer a warranty, of course.
Old 07-14-2016, 03:12 PM
GT6ixer
GT6ixer's Avatar
Dave
+1 Was thinking the same thing. How flexible is that filler when cured? For example could you apply it to a flat piece and then roll it over your knee without it cracking?
I may be a future customer. The test pod looks great!
Old 07-14-2016, 03:39 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
I would conduct extensive long range testing before deciding to go into this business. Others in the past have done body filler repairs that looked good for a while and then the filler and the crack started separating. Some have covered the entire surface with fiberglass body filler to combat the later cracking.
Offering a warranty is nice as long as you know exactly what you are getting yourself into and what the failure/return rate of your product is. If the owner has to cover the labour to remove the dash, this warranty will means little to them.
Old 07-14-2016, 05:14 PM
M. Requin
M. Requin's Avatar
The first pod repair I did like that failed after about a year, and it was really disappointing when the cracks reappeared. The second time I filled the cracks as before, and then added a layer of non-woven roving, bonded with polyester resin. That way, if the cracks reappeared they would be underneath this polyester skin, which would remain intact. It has, with no car or windshield cover, no garage, etc. for over two years now. I really think the secret is NOT relying on repairing the original surface, but building a new surface that won't crack. Link here: https://rennlist.com/forums/928-foru...h-project.html
Old 07-14-2016, 05:47 PM
Kevin in Atlanta
Exactly right. And without going into a lot of detail that is a part of my solution. Though, I did not use what you did. It is similar in concept. Only time will tell.
Old 07-15-2016, 01:26 PM
Kevin in Atlanta
The pod is in a parts car and according to the thermometer the temp on the pod surface is 172-174 degrees. By no means a test - but it will remain there for a while.
Old 07-15-2016, 01:30 PM
M. Requin
M. Requin's Avatar
Great minds ...
Old 07-15-2016, 01:59 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Now take it out and put in in a freezer for a day then, back into the parts car.....repeat this until you see cracks and then calculate how many cycles it took to get there. Yes this is an extreme way of testing but it will represent reality in an escalated scale. Otherwise it will take years if you just let the pod sit in the parts car.
Old 07-15-2016, 03:24 PM
Kevin in Atlanta
Freezer. Hee hee.
Pulled the pod and let it cool. You can see faint lines where the cracks were. The glare makes it look worse. I still love the texture.
I need to review my patching steps and make some adjustments. Body work has never been my forte.
Quick Reply: Need Pod Cores for a business start-up
