S4 transmission problem
I believe you are looking at the kickdown solenoid on the transmission. I've never removed one, so I can't help much there..........
OK well the good news is that I've potentially found the problem. I think I should be able to get enough play to take it out completely if I undo the bolts holding the linkage cables in place. Now to find a new kickdown solenoid.....
Filling capacity approx 8.0 l (from model 87 approx. 9.3 l)
Oil change capacity with converter approx. 6.0 ltr.
(from model 87 approx. 7.3 ltr.) ATF-Dexron II D
I'll change the ATF again when the filter and solenoid arrive, I won't really be driving it until then - it looks like about 7.3L is what I should be expecting?
In the meantime I'll devise a plan to remove the busted solenoid and will post the procedure when I get to it, it might be useful for someone down the track.
6L for the both the convertor and the oil sump is not enough.
Get the transmssion warm and check your fluid level, before you go too much farther.
On Speedtoy's freshly rebuilt transmission, he was apparently using 1st gear to start, after the rebuild. The secondary oil pump is apparently active when starting in 1st gear (from what I can tell from the literature.) Anyway, the two gears for the governor stripped (apparently a common problem in the Mercedes version of these transmssions.) Once the governor stopped rotating, shifting became...very strange. I'm sure Jeff can elaborate on the shifting problems...I drove it around the parking lot, knew somethng was wrong, and took it out.
I dont start in first a lot, but sure..I do some.
My failure mode was one day coasting down the mountain road in rush hr traffic, This would be..for maybe 2miles, and only on the morning side of the mountain, never on the way home at night.
But one day, doing about 15-20mph as usual, the car downshifted to 2nd gear, and would not upshift.
Once I got open area near the highway, I discovered I could start in 1, but would not upshift. I had to go into N, wait, put in D, and I could get 2nd gear, but no more.
Upon rereading the above, Speedtoys' symptoms are very similar to mine and part of me fears that I broke the solenoid myself when I was undoing the hex head pin next to it!
Greg, are you inferring that if I still have the problem after replacing the solenoid, the next step would be to replace the governor gears, or the secondary pump parts, or both?
Hi. I like this colour a lot in the 928 S4 shape. Did you buy this car from an owner in the western suburbs of Melbourne? If so, this owner had undertaken quite a bit of his own maintenance on the vehicle.
Cheers
Cheers
Update.
I replaced the kickdown solenoid with a brand new one. While I was there I changed the ATF, filter and gasket. I have checked and triple checked that the ATF level is right. BTW, the refill amount was 7.5L.
But I still have my problem. The thing I find strange is that it's fine until the ATF warms up. So it seems to have something to do with the changing characteristics (viscosity or expansion) of the ATF once it is heated.
That aside, from Greg's post here and also the troubleshooting section in the manual I am led to believe that the cause could be the centrifugal governor. My next step is to take it to an expert to diagnose the actual problem so that I then know what I am up for.
Basic Site Sponsor
Basic Site Sponsor
Update.
I assume that since you have messed with the kickdown solenoid, you realize that the "O-ring" on the actual solenoid should be not visible and inside the electro magnet?
If you drop the filter, the valve body, and the intermediate plate, you can actually see the governor/secondary pump gears.
Will report back when I know more.
Basic Site Sponsor
Basic Site Sponsor
Even more amazing is that Porsche, in Pet or the Workshop Manual doesn't acknowledge that many pieces got changed when they eliminated the darn thing.....no changes in part numbers even though the pieces are completely different visually.
I did finally get into the Mercedes factory parts program and was able to go through every single model and year of the 722.3 transmission....one at a time! I was able to determine when and which model the secondary pump was removed and I have ordered some pieces from Germany to compare to the GTS pieces (GTS does not have the pump.)
I have details of all the differences in the valve bodies, from year to year...and there is only a couple of subtile changes in the GTS valve body.
Speedtoy's transmission works with the pump removed...it has got one glitch that needs to be solved. (Won't shift out of 2nd gear at WOT, when manually shifted.)
Hopefully, a couple of these obscure pieces, from Mercedes, will solve this.
Basic Site Sponsor
Basic Site Sponsor
I think figuring out how to build and then get the pieces to build a nuclear weapon would be easier that figuring out this.
Either there are very few people that understand all of the changes in these Mercedes transmissions and understand what each chang does, or these guys are the most secretive people I've ever run into.
Even more amazing is that Porsche, in Pet or the Workshop Manual doesn't acknowledge that any pieces got changed when they eliminated the darn thing.....no changes in part numbers even though the pieces are completely different visually!
For instance: The B1 operating piston got updated to a self adjusting (compensates for band wear) piston in the later 928 transmissions. Fantastic upgrade....keeps B1 band pressures optimized as thing wear!
Good luck figuring out what that part number is....even though there are Mercedes part numbers stamped into the pieces!
I did finally get into the Mercedes factory parts program and was able to go through every single model and year of the 722.3 transmission....one at a time (crazy tedious). I was able to logic out when and which model the secondary pump was removed and I have ordered some pieces from Germany to compare to the GTS pieces (GTS does not have the pump.)
I have details of all the differences in the valve bodies in the 928s, from year to year...and there is only a couple of subtile changes in the GTS valve body.
