928 Forum 1978-1995
Sponsored by: 928 Specialists
Stripped Lower Girdle Hole
Old 05-13-2016, 09:14 PM
Kevin in Atlanta
Kevin in Atlanta's Avatar
Default Stripped Lower Girdle Hole
It's the one that secures the ground strap from the body. I think a ham fisted mechanic overdid it when they added a second ground strap.
Of course, I didn't find out until the engine was in.
Any advice on the best course of action? It looks like I have make the mounting hole on the lower girdle bigger to get a time sert or whatever is the latest recommended insert. Maybe not?
And a follow-up question can oil seep out from between the block halves if the bolt can't be properly torqued?
Old 05-13-2016, 09:28 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Connect the ground strap to a different location.
Old 05-13-2016, 09:47 PM
GlenL
GlenL's Avatar
Pic? I think the ground strap doesn't go to a girdle bolt.
Old 05-14-2016, 03:23 AM
OTR18WHEELER
You can call me Otis
OTR18WHEELER's Avatar
I had my lower girdle hole striped once,...or twice.
Old 05-14-2016, 08:34 AM
GlenL
GlenL's Avatar
Old 05-14-2016, 10:16 AM
Kevin in Atlanta
Here's a picture
Old 05-14-2016, 02:15 PM
ltoolio
ltoolio's Avatar
Old 05-14-2016, 02:59 PM
SeanR
SeanR's Avatar
Who put all that goo on the oil pan gasket? And yes, the ground strap always goes through that girdle bolt.
Old 05-14-2016, 06:06 PM
Kevin in Atlanta
I may have gone overboard on the HondaBond.
And to the right you will see oil coming from between the upper and lower blocks. So, either I had a sealant failure or something else not right. Needless to say the engine is coming out to see what went wrong. I promise to go easy on the HondaBond next time.
Old 05-14-2016, 06:14 PM
GlenL
GlenL's Avatar
I was under a car and thinking that ground can go on somewhere else., like the lower bellhousing. I don't think that bolt is important, structurally. You might try a slightly longer bolt as there may be threads deeper in. Torque lightly in that case.
But if you're taking it out you can check all that. If you take it apart, get the loctite 574 and apply a very thin coating. I'm not sure I'd re-rebuild it for that weeping...at least not right away until I could see the real magnitude of the problem.
Old 05-14-2016, 06:56 PM
Kevin in Atlanta
I followed the WSM and used loctite 574.
Old 05-14-2016, 08:22 PM
GlenL
GlenL's Avatar
Oh... so the hondabond is on the oil pan gasket
Old 05-14-2016, 10:51 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,253 Likes on 1,247 Posts
I would get a stud and and JB weld it into the block,
let it cure then bolt the wire to it ,
put a star washer under the ground strap
Old 05-14-2016, 11:44 PM
heinrich
928 Collector
heinrich's Avatar
Seems easy. Tap it a little bigger.
Old 05-15-2016, 12:58 AM
Kevin in Atlanta
I think that is brilliant!
Quick Reply: Stripped Lower Girdle Hole
