928 Forum 1978-1995
Sponsored by: 928 Specialists
Fuse 24 Again
Old 11-22-2015, 04:43 PM
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
Mongo's Avatar
Angry SOLVED: Fuse 24 Again (PAGE 8)
I blew 7 fuses this morning in fuse 24 just by inserting it.
I tried inserting even with the battery disconnected and no luck. Once reconnecting it the fuse would go pop too disabling the interior lights.
I have pulled the roof lights for the typical ground out issue and no success. Not sure where to go from here. There is no fuse in socket 24 since just inserting it blows it out and I don't want to destroy my CE panel.
Looks like I am now a Fuse 24 Club member.
Old 11-22-2015, 06:05 PM
Mongo
Fuse 24 Assassin
Mongo's Avatar
Not sure if this is related or not but I notice my e-brake does not ratchet or click anymore when pulling it up. Searching here has revealed there are wires in that area for the hatch release.
Old 11-22-2015, 06:24 PM
Alan
Electron Wrangler
Alan's Avatar
The interior light power goes there for the hatch switch - check that - easy to remove the cover to see...
Also remove the door lights and check.
Have you changed anything in the pod or worked on the speakers at all recently?
Alan
Old 11-22-2015, 06:28 PM
Ducman82
Ducman82's Avatar
Sounds like a chaffed wire in a door or hatch
Old 11-22-2015, 06:34 PM
Mongo
Fuse 24 Assassin
Mongo's Avatar
Alan I installed a narrowband AFR 2 years ago. It has worked fine until today. It is non-functional but was added via add-a-circuit to the AC fuse slot. So I have issues
Old 11-22-2015, 06:37 PM
mj1pate
mj1pate's Avatar
My 86.5 was blowing the interior light fuse regularly until I figured out the short circuit was coming from the hatch area. There is a ribbon cable that runs between the roof and the hatch. The span of cable in the area between the roof and hatch is an opportunity for ribbon cable chafing. Removing the trim under the hatch is easy and you should be able to inspect the cable for chafing shorts.
Old 11-22-2015, 07:02 PM
MainePorsche
MainePorsche's Avatar
Also here are wires for E-brake central warning. Connector attacks to base of brake arm.
Old 11-22-2015, 07:06 PM
Mongo
Fuse 24 Assassin
Mongo's Avatar
I think I know what it is. I had the parking brake cover off when I took my seats out for a major carpet cleaning. I bet when assembling I may have moved the orientation of those hatch release wires. They are probably binding with the assembly and shorting. Doesn't the hatch release operate off of fuse 24 too?
Old 11-22-2015, 07:17 PM
MainePorsche
...Doesn't the hatch release operate off of fuse 24 too?
Yes, hatch switches do run off of Fuse 24. There is also a direct tie in to ignition switch to Fuse 24.
Old 11-22-2015, 07:26 PM
MainePorsche
WD for hatch switch.
Old 11-22-2015, 07:29 PM
Mongo
Fuse 24 Assassin
Mongo's Avatar
This helps! Thanks! My one year old just awoke from a nap so this will have to wait until her bedtime.
Old 11-22-2015, 07:34 PM
MainePorsche
Sounds like baby play time...
Old 11-22-2015, 07:40 PM
MainePorsche
Glove box lamp is directly in the mix too.
Old 11-22-2015, 09:39 PM
Rob O
Rob O's Avatar
It's definitely a short.
The easiest way to find it is putting an automatically resetting fuse (find it at auto parts stores located with other regular fuses) in place of a normal fuse with the key off. Get a compass ready. Turn the key on. The compass will point to the short. The resetting fuse will continue to reset itself because of the short and the compass will alternate between pointing north and towards the short. Just move the compass around until the signal is strong and obvious where it's pointing. It works because a magnetic field is created by the short.
Old 11-22-2015, 09:54 PM
MainePorsche
Rob,
Never heard of that maneuver. Thanks. Very interesting, and good to know. My old undergrad physics comes back to me now.
Quick Reply: Fuse 24 Again
