928 Forum 1978-1995
Sponsored by: 928 Specialists
Temp II sensor for dummies
Old 10-07-2015, 04:46 PM
safulop
safulop's Avatar
Default Temp II sensor for dummies
OK, I'd like to replace the temp II sensor on my S4. I don't normally work on my car, but I have a few tools. I do have work-shop manuals. Is this easy or hard?
Old 10-07-2015, 05:08 PM
davek9
davek9's Avatar
Easy.. unplug it and unscrew it, install is the reverse (no water will leak out).
Old 10-07-2015, 06:26 PM
safulop
safulop's Avatar
Uh, it's the one on the water bridge toward the passenger side right?
MainePorsche
MainePorsche's Avatar
Make sure threads are clean for proper grounding.
Old 10-07-2015, 06:27 PM
MainePorsche
Yep, that's Temp II.
Old 10-07-2015, 08:16 PM
SMTCapeCod
SMTCapeCod's Avatar
Anyone happen to know diameter/thread pitch?
THinking of a thread chaser to ensure powder coating is outta there on mine.
Old 10-07-2015, 08:52 PM
SMTCapeCod
SMTCapeCod's Avatar
whups, inadvertent double post.
Thanks, Ed! Everytime I think I'm asking something so foolish/unlikely that it probably hasn't been addressed before, I'm reminded of all those that have gone before!
Old 10-08-2015, 10:31 AM
Andre The Giant
Andre The Giant's Avatar
What does the temp II sensor do, is it the one that tells the electric fan on MY'85 to start ? The other fan works with the engine.
Old 10-08-2015, 12:36 PM
Ed Scherer
Ed Scherer's Avatar
An old post of mine might answer that question. I think it's M12×1.5.
Old 10-08-2015, 12:39 PM
bureau13
bureau13's Avatar
No, there's a temperature-controlled switch in the front (lower, driver's side) of the radiator that turns on the aux fan. The Temp II is the one the car uses to make it run properly...I'm guessing it is for fuel based on how warm the engine is? But I'm not sure exactly how it's used. There's a different one for the gauge and overheat lamp.
Old 10-08-2015, 12:42 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,072 Likes on 1,183 Posts
Why are you changing it?
Old 10-08-2015, 12:57 PM
Andre The Giant
Thank you Jeff. I will look on the PET to see where that aux fan switch is, it's bugging me !
Old 10-10-2015, 12:22 AM
safulop
safulop's Avatar
Car has had some issues over the summer, got a bunch of things taken apart and put back together in search of the answer. The only remaining problem is that the cold idle is too high, but settles slowly down to spec idle when engine is warm. There is an accompanying drop in gas mileage.
While my shop said the Temp sensor was operating correctly, they likely only tested it warm. The sensor has a whole range of resistances it is supposed to provide to the LH, and if it is reading too high at cold temps then the LH will send too much fuel which will increase the cold idle speed and reduce the mileage during short trips, which is mostly what I do driving 6 miles to work and back each day. So possibly changing to a new Temp sensor might fix this weird problem.
Old 10-10-2015, 01:42 PM
John Speake
John Speake's Avatar
The idle control loop is designed to give a higher idle speed when engine water temp is below normal running temp. It's a closed loop system, so fuel enrichment won't alter it.
Cold idle speed is typically 200 to 300rpm higher than the hot idle speed of 675rpm for an S4.
Old 10-10-2015, 03:59 PM
safulop
safulop's Avatar
Yeah, mine is idling up to 1600 when cold-started. It slowly settles to 675 as it warms. The idle speed is definitely dependent on coolant temp, but it is just way out of the normal idle speed range. So one idea was that the temp sensor resistance could be out of whack at colder temps. But it's good to learn that the excess fuel part of the logic there is incorrect, thanks John.
Quick Reply: Temp II sensor for dummies
