928 Forum 1978-1995
Sponsored by: 928 Specialists
Engine Block Coolant Plugs - Both Removed?
Old 05-31-2015, 01:24 AM
ltoolio
ltoolio's Avatar
Default Engine Block Coolant Plugs - Both Removed?
Currently working on getting some new coolant in my system due to my cap issue encountered a month back.
My plan is to drain, fill with 4 gallons of distilled water, run the car a bit to circulate, drain again and then refill with a 50/50 mix of water and Zerex G-05.
The car is currently draining at the PS side engine coolant bolt, but the DS side looks to be a bear to get to.
Given my plan of the intermediary step of the flush with the 100% distilled, and given that the bolts are currently level, is it necessary to remove both PS and DS bolts?
I'm hoping not, but assuming the answer is yes.
Old 05-31-2015, 02:15 AM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,556 Likes on 1,235 Posts
Answer is yes. Each bank of cylinders is its own water jacket.
Old 05-31-2015, 02:17 AM
ltoolio
ltoolio's Avatar
Yep. Just came in to report the exact same. Got it off and down came the shower of coolant.
Thanks for the confirmation.
Old 05-31-2015, 11:05 AM
jcorenman
jcorenman's Avatar
Don't forget fresh aluminum sealing-washers for the re-install, anti-seize, and torque to 19 ft-lb max-- the torque spec in the book is wrong.
See Dave's thread here: https://rennlist.com/forums/928-foru...-is-wrong.html
Old 05-31-2015, 05:26 PM
ltoolio
ltoolio's Avatar
Job finished.
Flushed twice for good measure (like other aspects of my life )
Crush Washers on, anti-seize on. Ended up torquing by hand due to the confined space and my lack of confidence in being able to get a good read. Snug, but not block-crushing. 2 gallons of distilled water, 2 gallons of Zerex G-05, pre-mixed, poured patiently with towels wrapped around the coolant tube.
Took her out for a drive and all good. Will monitor for leaks.
Thanks for all feedback / tips / info. Love this board.
Quick Reply: Engine Block Coolant Plugs - Both Removed?
