Heat reduction in aftermarket alternator
#61
Also, Mark,
I looked really hard to find efficient electric fans. There is no electric fan that will cool a stock, much less an upgraded engine, at idle, in 90 degree weather and draw 10 amps. Just not out there. Can't do it with 20 amps either. I can just barely do it with 35 amps. with really efficienct fans.
Sorry,
Dave
Sorry,
Dave
i think the stock S4 fans were 10amps each as well... maybe im wrong there, but its the stock stuff, so its a known quantity. so, if we are debating the current draw, fine, either way, the stock stuff does it. it doesnt push my little 13lb battery at all, and the alternator (stock GT) works fine for the draw of the fans and the current the engine requires, plus a 500wattt stereo blasting away.
Mark,
At mid throttle rpm's I have always had plenty of voltage too. In bumper to bumper traffic at 800 rpm, with high load and high ambient temps, I get 10.6 volts. I bet you are not racing in bumper to bumper traffic at 800 rpm. If I was driving at any kind of speed, my alternator would give plenty of juice too. Unfortunately, that is not always the case. Have you ever seen an alternator output curve of amps vs. rpm? Your 80 amp alternator is not giving you much more than 30 amps at idle. Sorry, but I think that is true for me, and most other people too.
Thanks for trying to help.
Dave
Dave
Mark - I'm not sure what you mean by this? but the alternator certainly doesn't provide more current as the voltage drops... in fact the voltage drops because the alternator can't supply the power that is being asked of it at its rated voltage setpoint - Voltage must droop to compensate - its the only way the power goes down (so voltage & current both drop). Now the stock regulator is indeed a little over aggressive in regard to temperature deration.
This is the critical element here - ambient temperature and local "ambient conditions" at the alternator in particular that drive the regulator temp. deration.
In Phoenix at 120F you will not find a 928 Bosch alternator that will make good power (and sustain set point voltage) at low (idle) RPMs with a heat soaked engine. Remember under these conditions the AC & blower will be on max and the cooling fans will likely be on at full power almost constantly. Make it night time with lights on and even if its a little cooler say 100F-105F+ it will be no better. Bring your car here in July and find out for yourself.
The issue is very real but primarily only for very hot environments, if you see similar somewhere cool - you have some other issue (regulator/diodes... etc)
Alan
Alan
if you do, you have an alternator issue.
Lets talk about voltage drop, im talkiing about the alternator response to "voltage drop".... the alternator puts out more an more voltage,which produces current as it sees the voltage drop of the battery. that's how it works. it tries to keep the voltage at a set level of 13.5-14volts. if it cant sport 13.5volts, that's when the voltage starts to decay and this means you are above its power capabilities and thus its current limits.
all you need to do is find a good running 928, turn on the works and let me know what your fluke meter shows.... the stock alternator will work fine at high temps and will not go below 12.6 volts.
#62
Hi Mark,
I always enjoy your information. However, I don't think your fans are 10 amps. On my car, cooling is a challenge because I have a large supercharger right behind the radiator, blocking air flow and taking the space of a puller fan, factory or otherwise. Your voltmeter is disabled while the starter is running, so I can't tell what my system voltage is, probably 12.4 for a while. Anyway the alternator plays no role while the starter is running. The alternator does not put out its full rated output at idle; it makes maybe 30 amps, even yours. If your load exceeds that, the battery supplies some. The battery will not do this for long. I don't know if you have expressways with rush hour traffic jams near you, but for me, when I'm stuck in one, there is no way my voltmeter stays above 13 volts. This is the fourth alternator I have had on my car, and none of them delivered good voltage when heatsoaked at idle. I am really glad you have had such good success, but I have not. Until lately, I have finally been doing better.
Thanks,
Dave
Thanks,
Dave
#63
Developer
Be sure your battery is in excellent condition. An older battery will have resistance to charging and that appears as low alternator output when testing. It is for this reason that many alternators come with a specification on their warranty that requires the battery be replaced when the alternator is replaced. It prevents false warranty claims.
An FYI: a lot of 928's don't get driven very much. My 91 is one of those, and I can put a brand new battery in it and that battery will be garbage in 3 seasons because the car sits so much. The lead plates just sulfate until he battery will not take a charge at all.
Better: Get rid of the wet lead-acid battery and get an Optima Red. Because it is a gel-cell and not wet, (and because of a few other technological advancements) the Optima's are unaffected by sitting for long periods and still work great. The first Optima red that was in my race car is now in our fork lift and still going strong - probably 12 years old now. They aren't cheap in the short term (about $150), but less expensive in the long run.
You do not need a big one. The 24R works fine for me.
I don't sell batteries - not selling anything here - just offering advice....
#64
Dave
#65
Chronic Tool Dropper
Carl is spot-on with the need to look at the batery at the same time the alternator is replaced. Most alternator failures, and certainly many of our 'undercapacity' symptoms are the direct result of tired batteries. A good battery will not allow as much voltage to maintain charge current, or conversely will need more current for a longer time to recover after a casual discharge. Low voltmeter readings at idle are a symptom of a battery that's sucking current. The battery can't tell that the car is at idle, it just asks constantly for more current. At idle when current capability is reduced, all that current sent to a tired battery pulls the whole system voltage low. Then there's the deal with resistance between the alternator and battery that keeps the battery from ever reaching full charge; the battery can't support voltage needs at idle when the alternator is overworked and underfed. Hence the directive to replace the battery ground strap and the engine ground strap as early steps in the fight against the low-idle-voltage syndrome.
The Group 24 batteries have the terminals on top of the casing, rather than recessed slightly as the spec'd Group 48 that my can came with. The Group 48 batteries also have the correct "lips" at the bottom ends to fit in the factory retaining tabe and to use the factory hold-down. So if you decide to fit the Optima as Carl suggests, remember to get a standard 'murikan car hold-down bracket, the J bolts to go with it, and some adequate urethane pads to keep the positive terminal insulated from the battery box lid.
The Optima batteries don't seem to outgas the way wet-cell lead-acid batteries do, so you could forego the external vent hoses that fit the Group 48.
My new-to-me this year CTEK battery charger/maintainer has a dedicated charging profile for Optima and other gelled-electrolyte batteries. IIRC it has a different peak-voltage profile.
#66
#67
Rennlist Site Sponsor
An interesting thread. I do have one question...
Every "standard" automotive alternator fan that I remember seeing is basically a centrifugal type. They blow air outwards from the fan after pulling it from the rear of the alternator. Do the alternators that were discussed as blowing in from the ends and out in the center use axial-flow fans? If not, how does a centrifugal fan blow inward?
#68
Hi Wally,
My hose directs cool air to the rear center of the alternator, so the centrifugal fan can blow it outward.
Dave
Dave
#69
Hi Mark,
Thanks,
Dave
Thanks,
Dave
certainly you might have more challenge because of the blocking air inlet due to the supercharger, but that would only have the fans run longer on a hot day. certainly they might be a higher rating fan than the stock 928 S4 fans. you can easily put a volt meter on the battery during starting.... it very accurately measures the voltage drop, which pertains to a current flow from the battery. depending on the battery, the voltage drop will vary. generally, 400 to 500 amps will drop a battery in good shape to below 10volts. 60amps, on a health battery wont make much of a voltage hit to the battery. nominal battery voltage of 12.5 might go down to 12.0volts..... with the alternaltor running, it shouldn't go down much more than 14 to 13.5v.
#70
Thanks, Mark,
I completely agree with you. However, a 60 amp load will eventually lead to reduced voltage if the alternator is only making 50 amps, given enough time. Say 30 minutes in traffic at idle. I could be wrong. That is just the way my car seems to have worked.
Dave
Dave
#71
"Hi Wally,
Dave"
So does every other one that I have ever seen, thus my question...
Dave"
#72
I guess I did not understand your question. My alternator is an open cage design with fans at each end. They suck in from the end and blow out the edge of the case. I am unable to make a tight fitting shroud, so I direct forced cool air onto the rear face of the alternator where the diodes and voltage regulator reside. It is not as elegant as the factory cooling setup, but it does seem to help.
Dave
#73
Electron Wrangler
Alan
#74
OK - I have never looked at one of that type of alternator. So, if I understand what you are saying, the centrifugal fans are open to outside air in the center of the fan, and blow outward inside the closed end of the case, thru the case and outside thru vents at the middle of the case.
Of course, if you didn't have a source of cool outside air for the fans, you would still be using 200 - 250 degree air (heated by the AC, radiator and exhaust manifolds) to "cool" the alternator...
#75
Electron Wrangler
