928 Forum 1978-1995
Sponsored by: 928 Specialists
Passenger door will not unlock
Old 01-26-2015, 12:38 PM
vanster
vanster's Avatar
Default Passenger door will not unlock
My passenger door locking mechanism parished thus causing an electrical drain.
I unplugged it thinking that the door would remain unlocked. Replaced the door card, closed the door and now it's locked tight. Good news is that the window works and my electrical drain has been solved.
However when fussing with with it I broke off the 10mm stud that holds the the ****. ( the lock was frozen).
Old 01-26-2015, 11:09 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,255 Likes on 1,248 Posts
with the door panel off, stick your finger up behind the locking mechanism,
and see if a rod with a spring on it has come out of its position thus forcing the lock to move to a locked condition,
a simple push should put the rod back into its bore then the lock will be able to stay where its positioned.
The 82 was doing this and with a broken window motor you could lock yourself into the car as the **** is broken off inside and the only way to move the lock was with the key in the lock cylinder.
I was messing around with the lock and my finger went behind the lock motor and I felt the spring and with a lil push the lock suddenly unlocked.
I still have to replace the locking **** shaft
Old 01-27-2015, 11:44 AM
vanster
vanster's Avatar
Thanks Stan
However the door is closed and the door card is in place. I can't imagine getting how to get the door apart
to get behind the motor. Can a "slim jim" pop it open so at least I can get the door open then take the panel off?
Old 01-27-2015, 01:26 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
use the key and turn the lock this should force the mechanism to unlock,
while your holding the key unlocked pull the door handle
Old 01-27-2015, 04:46 PM
vanster
vanster's Avatar
Stan
I have tried this a number of times and it does not work. I can turn the key both ways and it does not budge.
Old 01-27-2015, 05:06 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
OK then take the door handle surround off ,
then remove the center section of the door panel off .
cut the vapor barrier and put a screw driver into the locking mechanism and pry the lock rod off,
then try to open the door
Old 01-27-2015, 05:22 PM
vanster
vanster's Avatar
Good idea....vapor barrier? long gone. Not sure but this happened after heavy rains
Yes, it does rain in California...or it did
Quick Reply: Passenger door will not unlock
