TPS Full Of Oil
Most of them are by now.
You can check ohms resistance for idle switch and wot switch at LH plug to see if still on spec.
That said, I would still clean it.
Regards
Dave.
Regards
Dave.
There are small o rings in the throttle body that no one ever replaces. This thread goes in depth with its replacement as that will leak oil into the TPS and cause a vacuum leak.
https://rennlist.com/forums/928-foru...-there-is.html
If it is within spec after getting oil filled I would still replace it so you don't have to worry about it again in the future.
It might be possible to replace just the seals - I haven't actually tried to measure and source the seal separately - I just replaced the bearings as a unit.
Roger I think has a solution to this. We all got into it a few years ago when Mike Frye did a write-up on 85/6 intake refresh. Dwayne also addressed this somehow in his S4 intake refresh writeup. I forget exactly where we all ended-up, will try to search it for you. Sounds like Hilton has most of the answer.
Bill Ball had discovered that his TPS had damage that was hidden, I think a cracked place in the metal contact spring thingy beneath the plastic. There are some posts / pics from the 2004/5/6 timeframe IIRC where he recorded his trials and tribulations over this.
I've taken a few apart, all with oil, but all seemingly working ok when metered. I thought the tps had orings itself, but maybe not. Yes, just cleaned them with WD, which is mainly mineral spirits, reassembled, no issues for mine. I think I messed with trying to manipulate the WOT trigger by bending the contacts to no reasonable solution.
Relevant threads I saved:
https://rennlist.com/forums/928-foru...le-switch.html
+1 on all the above posts.
My TPS was actually not in spec for the WOT switch anymore and I replaced, but I was really chasing down what turned into a computer problem at the time. I wasn't doing an entire intake refresh -- just chasing my tail, so I would love to get the definitive Roger solution before I take that project on.
From memory, Roger sells a more robust version with a seal on both ends, so not only does it hold vacuum in the throttle body, it also protects the bearing from ingress of dirt from the other side too.
