928 Forum 1978-1995
Sponsored by: 928 Specialists
I have an opportunity to buy 1987 CS
Old 11-19-2014, 05:05 AM
  #31
928cs
928cs's Avatar
Originally Posted by Hilton
If it has the original engine block, transmission, and VIN, then its restorable.
The ECU's had a different part number, but are actually functionally the same, with the only difference being the ECU chips, which can be copied to give the same performance, and the odds of finding a correct ECU are slim to none, unless Porsche still has new ones and don't just show a supersede in their database.
Everything else missing in the pics can be lifted from S4's of various years, except the CS sticker, which is NLA. (e.g. AC compressor from a 90-95 car, intake/heads/cams from an 89GT or SE)
Kevin - before considering buying, you need to get a photos of the engine block number and the transmission numbers.
Looks like it might be the Albrex supercharger kit which was the original 928 boost kit?
The engine block and gearbox numbers are the original ones.
I should have a original sticker soon (silver) and I will try to make accurate copies of it.
The ECU's need to be check. I suspect they are original to the car and as this car is a prototype the ECUs certainly also are.
With a lot of time and money, this car can be restored. But it needs someone who knows what he is doing to do it right.
Old 11-19-2014, 05:06 AM
  #32
928cs
928cs's Avatar
Originally Posted by Livio928
Are the side mirrors factory? I have never seen that type of mirror on any 928? What is the last picture of? Was someone trying to supercharge it? It seems that way with the red intake hose and what looks like a supercharger.
The mirrors are not factory. But regular ones are fine.
Old 11-19-2014, 05:08 AM
  #33
928cs
928cs's Avatar
Originally Posted by Cameron
Club Sport only had driver's side mirror.
NO. In fact, most of the ones I know have two mirrors and only two (or maybe three) factory cars have only a left mirror.
Old 11-19-2014, 05:09 AM
  #34
928cs
928cs's Avatar
Originally Posted by ROG100
Not if you paid extra for the passenger one.
It was free
Old 11-19-2014, 05:18 AM
  #35
Hilton
Hilton's Avatar
Originally Posted by 928cs
As I told you, no CS was ever delivered with a sunroof. That makes the following car more than suspicious to me:
http://www.classicdriver.com/en/car/...28/1988/149779
I think this car (wp0zzz92zjs845068) is a fake.
Seats?
Old 11-19-2014, 05:21 AM
  #36
928cs
928cs's Avatar
Originally Posted by Rob Edwards
Call me Robbyanna, and I wouldn't try to bite off that project, but OTOH if the VIN checks out, and the M28.41SP engine is there, and the G28.55 trans is there, and the CS-specifc LH brain is there (where else in the world are you going to get THAT sticker....) I would say that hulk is worth way more than zero. $5K of bodywork, $10K of paint, $20K of drivetrain work, $10K of interior re-work, plus the cost of purchase and intercontinental transport, You might break even..
RE: the list of CS-specific parts, here's the culled list of everything from PET
Code:
M 637	928 701 287 04	"sticker
tyre pressure"
M 637	928 111 094 04	intermediate silencer
M 637	928 111 093 04	intermediate silencer
M 637/639	928 111 271 03	dual outlet muffler tip
M 637	928 343 511 09	"front wheel spring
1 set"
"M 637
M 639"	928 424 067 50	gearshift lever
M 637/M 639	928 503 061 19	Rolled lip rear quarter panels
M 637/M 639	928 503 062 19	Rolled lip rear quarter panels
M 637/M 639	928 503 011 11	Rolled lip front fenders
M 637/M 639	928 503 012 11	Rolled lip front fenders
M 637	928 512 005 06	Rear hatch
M 637	928 551 089 07	handbrake cover without pull for rear hatch
M 637	928 551 505 07	Amp and fan amp passenger side cover without pull for rear hatch
M 637	E 928 559 339 00	Clubsport logo
M 637	928 559 339 01	Clubsport logo
M 639	928 618 124 22	EZK brain
M 637/639	> 928 618 123 14	LH brain
M 637	928 618 124 16	EZK brain
M 637	928 618 124 QX	EZK brain
M 637	928 618 123 12	control unit
M 637       928 603 011 01  alternator
M 637	928 603 035 02	ventilation element
M 637	928 603 135 04	alternator shroud
M 637	U 928 612 865 04	alternator shroud grommet for FOE harness
M 637	928 612 865 06	alternator shroud grommet for FOE harness
M 637	999 611 053 20	1976 to 1985 924 50 Ah battery
M 637	911 611 209 00	battery hold-down bracket
M 637	N 014 725 2	"pan-head screw
M 8 X 25"
M 637	N 011 525 13	washer
M 637	928 612 004 38	rear body harness '88 only
M 637	928 641 609 10	A/C and door lock console panel, without A/C
M 637	928 641 609 13	A/C and door lock console panel, without A/C
Remember that some of these parts can't be combined.
A real light CS has no AC and radio. I don't know if there was even one made, except the very first prototype.
Most of the cars have at least the AC, and only one production car (the very first one) has not the radio equipment.
Regarding this particular prototype, it was delivered with AC, a radio and a rear wiper.
Its equipment was:
M220: Locking differential
I298: Prepared for unleaded fuel, manual transmission
I328: Radio Blaupunkt Bremen SQR 46
M474: sport shock absorbers
I'm almost sure that a car with a AC and a radio must have the regular alternator, battery and wiring harness.
Old 11-19-2014, 05:26 AM
  #37
928cs
928cs's Avatar
Seats?
Correct no-electrical sport ones, but I'm not sure the yellow leather is original.
This car was the only CS delivered with regular S4 rims and suspension.
But the most important is that it was delivered without sunroof...
Old 11-19-2014, 07:03 AM
  #38
Vilhuer
Vilhuer's Avatar
If that was one of 10 '88 MY ROW CS it would be more interesting to me. Factory made all kinds of prototypes and they are obviously rare and all that but only '88 CS has separare VIN set which makes it little more special. In any case this proto should be saved. Big thing is are engine block and gearbox casting ok or not. Body is actually easier to fix than those if there is crack in the block or something like that.
Old 11-19-2014, 08:59 AM
  #39
Kevin in Atlanta
Kevin in Atlanta's Avatar
Default More documentation
I also have the attached PDF in German about the provenance of this car including an email from Porsche.
At the right price this could be fun... but without the delivered computers i am a bit hesitant to move forward with this.
Old 11-19-2014, 09:19 AM
  #40
Vilhuer
Vilhuer's Avatar
Computer is smallest problem for you. Especially when it really shouldn't even have CS part number since its prototype and actual part probably didn't even exist at the time when that car was made. It definitelly had non S4 maps in ECU's but part number on top of the boxes were probably normal S4 number. Easy solution for ECU is to check what map is in both boxes now. If they match or are close to GT maps then it's probably original from factory regardless of part numbers on boxes.
What is important is that engine is correct SP block and gearbox is original. Though engine might not have same number what is listed in factory document, 81H00744. If it's same then it should be M28/41 SP 81H00744. G1G1 is guards red I think so that matches at least.
If you decide to pass it please provide details where it's for sale. I'm sure someone in Europe will save it if asking price isn't ridiculous.
Old 11-19-2014, 10:38 AM
  #41
Kevin in Atlanta
Stand corrected on the ECUs.
Could the supercharger be original to the CS?
So, what is it worth in Euros as it sits assuming the motor and gearbox are original?
Old 11-19-2014, 11:09 AM
  #42
928cs
928cs's Avatar
The supercharger is not original.
For the price, as I told you, send me an email and I will tell you how much the owner asked for it in May.
Old 11-19-2014, 11:56 AM
  #43
Kevin in Atlanta
I sent you an email.
Old 11-19-2014, 12:00 PM
  #44
Vilhuer
Vilhuer's Avatar
Lets assume reasonable 50K euro value for fully rebuild car. 10K for bodywork, 10K for paint, 10-15K for all needed parts. So maybe 10K on very very good day if one do not count any value for 1000+ hours it takes to put it together. If all work is done for $$$ real value is negative 30K euros or less because 50 euros/hour cost.
Old 11-19-2014, 12:06 PM
  #45
Kevin in Atlanta
As with the computers there was no CS gearbox at the time, right? I would guess the gearbox came off the line as a 87 but there is a possibility it was worked over for the prototype. More study is required. Already was working with RichVM on the possibility filling a container. Anybody need a GTS engine or two? 1990 GT Strosek? :-)
Certainly has my attention at this time.
Quick Reply: I have an opportunity to buy 1987 CS
