Diagnostic Run without Center Console
The center console is out for other reasons, but I've been trying to track down an rattle/squeak back there since buying the car. It would be nice to take a quick test run so see if I can either track the noise down or see if it was the console itself rattling.
The missing systems would be the HVAC head unit, the passenger tray bulb monitor, the interior temp sensor, the AC switch, and the central warning button/lock panel. I'd insulate the loose leads for the clock and ashtray to prevent shorts there.
Would this overheat/blow anything else?
