Power lock controller
The WSM calls it the controller or winder. Anyway the passenger power door lock just stopped working, but you could hear the electric motor humming away inside the door.
So this is literally about the 15th time I have had these door panels off this car and getting the controller out of the door was a PITA.
Looks like the plastic winder arm shaft has sheared in two, big surprise for 32 year plastic.
Other than trying to epoxy the shaft back together, which may or may not hold with the high torque of the little electric motor winder. I would imagine the entire controller is NLA and would have to sourced used from Roger or 928 Int.
Any suggestions as I am going to Gorilla epoxy and clamp the parts together tonite.
