Coolant in engine valley ?
My car is currently in my friends shop, having an ongoing misfire/vacuum
leak detected. When the associated hardware / plenum etc was lifted out
there was old oil ( expected anyway) but more worrying there was an
amount of coolant lying in the vee of the engine. Is this common and what is
the fix, as there dont appear to be any coolant hoses there. Incidentally
when I,m on, . Iv,e left the problem with my friend who is familiar with K
-jetronic systems having learned his trade when they were the popular
injection system, late seventies early eighties., he has discovered when carb
cleaner is sprayed around the base of the fuel distributor, in just one
particular part, the engine will "bog" down and stall, this is what he,s
currently trying to establish ie possible air leak when I saw him last. I think
this is the problem when driving the car, if you put your foot down hard on
the gas peddle it will stumble and almost cut out which it has been doing..,
dist cap, rotor, new beru leads, and spark plugs have also been replaced
This is on a 928 S, 1980 with K-jetronic injection.
Ken
80 928 S
5 Speed
UK
Ken
80 928 S
5 Speed
UK
The large o ring at bottom of water bridge is leaking coolant. Time to replace it along with the other gaskets and the seal behind the thermostat.
RE coolant: Search for discussions, several, on "water bridge"
I'm not familiar with fuel distb. but it sounds like a leak. A top end refresh of vacuum bits may be in order.
.., thanks I,ve checked out some" water bridge " posts known in UK as " Thermostat housing" confusing ? and that job seems like fun with all the associated pitfalls... !
I forgot to mention,. some time ago I replaced all vacuum hosing with silcone hosing.
Ken
80 928 S
5 Speed
UK
I just had this very issue... and it turned out to be a hose clamp that wasn't fully tightened.
I recommend looking for a pressure tester like this:
It's available for about $30 on eBay, so not too much for peace of mind that you have everything installed correctly.
A leak-free system will hold 100 kPa without too much issue. A normal cap will pop around the same value... perhaps slightly less.
A slow pressure drop is not a big deal, since you test while the engine is cold. A hot engine will usually tighten up clearances.
Team Owner
on the older cars you want to check the rear water outlet,
and the rear block off plate.
also look along the head to block area for white crusty deposits,
if you see these then your headgasket is weeping coolant and this could also be a potential for a leak
It could also be where the heater control valve is attached to the engine, right rear of the engine. Plenty of these elbows have corroded so bad that they fail, leaking in to the valley.
Yep, that more than likely is the block off plate at the rear of the engine. by the way, dont plan on trying to remove those bolts. or if you do, be CAREFUL!!! you run a risk of spinning off the heads and being left with a mess. I did it, some how, my mechanic at the time, was able to drill and tap just to the outside of the broken bolt and put a new bolt on. it worked and was lucky FOR sure
...,very many thanks to everyone who took the time to offer their advice , very much appreciated and FYI., I had a call this morning to pick up the car, my friend who does the major stuff for me rang to say she was running great. he had worked on the car all day and untill 10 in the evening when his staff had finished for the day, he likes it that way so as to no distractions and everything went back in methodical order, the valley and associated injection stuff looks like new after he also cleaned everything in there. At this juncture I dont know the exact details of how he fixed it, but suffice to say she has definately got her get up and go, no misfireing and lots of power. Couple of things which I,m wondering over is the tickover is high, approx 950rpm, manual box. I mentioned this and he said give it a few days and see if it settles, if not he will reset it. Got home just now and left the car for an hour, and it,s not as high, but I,ll give it a couple more days.
Second thing , and this has me stumped, I,m getting no cold air from the centre vent, but was before the work was done and marginal cold air to the screen ? The only thing that I can think of in the area he was working was the heater valve, of which I keep a new one in my garage !
Thanks again...,
Ken
80 928 S
5 Speed
UK
Thanks again...,
Ken
80 928 S
5 Speed
UK
He may have knocked off your vacuum line to the A/C valves, it has the blue/back valve that hooks up to the brake booster through a short vacuum line. That is one easy area it could have been knocked off.
It is also possible he knocked off or broke the black vacuum line that runs into the interior.
He could have also forgot to hook up the heater valve causing a large vacuum leak that will remove all vacuum tot he other valves and not allow them to function.
I have suffered through all of this, and this is just my personal experience, but I hope it helps
Ken
80 928 S
5 Speed
UK
You need to observe it in action. Does the piston move in/out when you change the slider on the control dash from cold to hot? This would be with the engine running, you'll need an assistant. Even this is no guarantee. Mine moved, but the channel through which the coolant passes was jammed by an internal gasket inside the valve that was out of position. So it couldn't completely close off the flow.
Ken
80 928 S
5 Speed
UK
