Impulse Buy for the S3
So I came across this shift **** on local CL.
I Thought it would look freaking good with my aluminum shift gate.
The seller was an old guy cleaning out his shop.
He insists it's OEM. If it's aftermarket I've never seen the like.
Solid chrome, I could not find the equivalent with online search.
356 vintage?
Anybody know where this came from?
Attachment 839116
Attachment 839117
Attachment 839118
356 vintage?
Attachment 839116
Attachment 839117
Attachment 839118
Yes, I'm pretty jazzed.
I want it to be the center piece of the car.
I've only been home 10 minuets, I ran past my wife and posted it immediately!
It's seems to be a 10 metric hole.
I'm going to work with an aluminum adapter tonight and come up with a plan.
Archive Gatekeeper
Looks like the same cloisonne insert as the old Amco 356 ***** used, but I've never seen a chrome **** like that. That'll look really cool!
Thanks guys.
I will try and put it to good use.
I tapped a 10 mm hole in my adapter very carefully.
Then cut the head off a 10 metric screw so it could be threaded from both directions.
I added some over all length on my short shifter by doing this, so I cut and notched the short shifter down further.
To make the fork on the adapter secure to shifter arm, I plan on drilling cross holes and using some recessed hex screws.
Attachment 839156
Attachment 839157
Attachment 839158
Attachment 839156
Attachment 839157
Attachment 839158
Still better as a shift ****.
So it's in.
Tapped 3, #8 set screws to hold adapter to shifter arm.
Used black Marine wrap to tidy up column and eliminate metal to metal vibration on the shift gate.
Attachment 839328
Attachment 839328
