928 Forum 1978-1995
Sponsored by: 928 Specialists
Oil pump ???
Old 04-14-2014, 09:23 PM
IcemanG17
IcemanG17's Avatar
Default Oil pump ???
I know there were two versions of oil pumps in our 928's...the early cars had 21mm wide pumps and the later cars had 23mm to increase idle oil pressure, maybe to reduce drivetrain noise I would guess?
Okay my questions, what is the drive ratio of the oil pump vs the crankshaft? It is under driven, but at what ratio? I don't think this ratio changed when the pumps got larger?
While the pump runs extremely high pressure (100psi+) at high rpm, what is the flow rate in GPM? I know the factory rating is 1 bar per 1000rpm, with at least 5 bar at 5000rpm.
I recall someone did the calculation on the pump and quoted 3.95 GPM per 1000 rpm, but did not state if that was actual pump RPM or crank RPM....I doubt our engines turn 24gpm at 6000 so its probably oil pump rpm, but is still a much higher volume oil pump than many other engine designs?
Old 04-14-2014, 09:50 PM
ptuomov
ptuomov's Avatar
https://rennlist.com/forums/7629783-post79.html
One other point I'd like to comment on is that of oil flow volume and just how much oil volume must be handled by the sump cover and drain back system. Some calculations were done in earlier posts that showed the volume could be up to 21 gpm. The pump has losses and the already mentioned aeration bypass ports internal to the pump would reduce that volume by some amount. I was driving my GT a few days ago and took note of the oil pressure vs RPM. It isn't hot weather here now so the oil temp only got to 202F to 210F. The oil was Amsoil 20W 50. Idle RPM of 800 gave me 35 psi. The max oil pressure goes to 100 psi with hot oil then the pressure relief valve maintains that pressure. I get to 100 psi at 2400 to 2700 rpm. 2400 with oil temp 202 and 2700 at 210F oil temp. Oil that the pump supplies is bypassed at RPM above that. This tells me that the oil volume, at 100 psi, the engine uses is what the oil pump supplies at 2200 to 2700 RPM. With hotter oil the RPM for 100 psi would higher, depending on the oil. The engine uses, and the sump drain back system needs to handle, the oil volume the pump supplies at around 3000 RPM max. The remainder is merely bypassed and doesn't go through the engine. The engine use volume is nowhere near 21 gpm. Maybe 8-9 gpm.
Old 04-14-2014, 10:38 PM
IcemanG17
IcemanG17's Avatar
Thanks Tuomo.....I think you did the calculation I recalled at 3.95gpm per 1000rpm....I am guess at oil pump shaft rpm?
Old 04-14-2014, 11:12 PM
ptuomov
ptuomov's Avatar
Do not recall. But I have both sprockets here so I can count the teeth, unless someone already has the count. If you read that thread in the link, you can see various estimates with various credibility for pump capacity per pump teeth and pump revolution.
Old 04-16-2014, 04:45 AM
mark kibort
mark kibort's Avatar
Don't hurt yourself overthinking this one!!
Old 04-16-2014, 05:46 AM
928Myles
928Myles's Avatar
Brian,
oil pump gear - 35 teeth
crank gear 24 teeth
Myles
Old 04-16-2014, 09:51 AM
GlenL
GlenL's Avatar
With more valve lifters there's more flow needed on later engines.
What are you going for here?
Old 04-16-2014, 04:09 PM
IcemanG17
IcemanG17's Avatar
Originally Posted by 928Myles
Brian,
crank gear 24 teeth
Myles
Thanks miles
Old 04-17-2014, 05:54 AM
Roy928tt
Roy928tt's Avatar
Way back in the last century, when I was just a young apprentice , we were taught that 7 psi per 1000 rpm was all that was required.
After 30 years in the trade I've yet to discredit that rule of thumb.
Quick Reply: Oil pump ???
