928 Forum 1978-1995
Sponsored by: 928 Specialists
Intake/exhaust cam relation/timing, chain marks
Old 12-29-2013, 10:48 PM
jcorenman
jcorenman's Avatar
Originally Posted by 17prospective buyer
So if i set the timing roughly, ie just line up the gears and marks by eye, is that ok? How many degrees of cam rotation leeway is there before valve contact.
Yes, that's fine. Center the gears on the cams, get the belt on correctly (i.e. marks line up after tensioning) and you should be within a couple of degrees. I generally leave it like that and do the final timing with the 32v'r after 1000 miles or so, after the belt has fully "settled". Or, set it now with the 32v'r, and check it later.
I am not sure how far you can be off without damage, but I think it is at least 2 or 3 teeth (7.5 deg per tooth).
Cheers, Jim
Old 12-31-2013, 01:18 PM
17prospective buyer
17prospective buyer's Avatar
Good news, i got it roughly timed at least. Left off by 1 tooth, right off by 1 1/2. Not bad for doing it alone though. Before i made the mistake of leaving it at 45 BTDC when lining the cams up.
Old 03-01-2016, 01:12 PM
Kevin in Atlanta
Kevin in Atlanta's Avatar
I am assembling 1990 S4 engine that a Porsche dealership disassembled. The WSM references copper colored links. I have only found one mark on one of the chains. Did something change on the chains in the later years?
Old 03-01-2016, 03:08 PM
Lizard928
Lizard928's Avatar
Nothing changed on later years. The copper colored links should be 7 apart. Set then measure for the 113mm.
Old 03-01-2016, 03:25 PM
Kevin in Atlanta
I'll have to look much closer.
Old 03-01-2016, 03:52 PM
Kevin in Atlanta
One chain has them the other, not.
Old 03-01-2016, 03:56 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,556 Likes on 1,235 Posts
The color of the links is immaterial, they're all the same metallurgically. I can't see the 'humps' on your cams in the pic you posted but if the humps are both pointing straight up and you have seven link endplates between the humps, you're good.
Old 03-01-2016, 04:01 PM
Kevin in Atlanta
Yes the cast lugs are in the correct position per the WSM - so I am good to go.
Quick Reply: Intake/exhaust cam relation/timing, chain marks
