928 Forum 1978-1995
Sponsored by: 928 Specialists
16V euro heads....before-after pics
Old 06-28-2013, 11:51 PM
danglerb
danglerb's Avatar
Originally Posted by BC
The assumption that there is no gain going from an older OEM ecu to a new aftermarket ECU is a fallacy and a false premise. The false premise is that Porsche did everything in their power to eek out as much HP as possible.
This is completely untrue.
Proper timing and proper fueling represent night and day differences on stock engines.
My assumption is that without adding air flow, changing afr, or timing, little will be gained. Is there something about the factory brain with a sharktune that prevents setting afr and timing to whatever you want?
Old 06-29-2013, 02:03 PM
IcemanG17
IcemanG17's Avatar
since its a pure race engine we can get 100 unleaded and 110 leaded......all are available at the track
keep in mind is pure stand alone.....so the fuel spark are adjustable however needed...
Old 07-04-2013, 03:08 AM
mark kibort
mark kibort's Avatar
290 rwhp is for Ljet and a good exhaust. (like equal length headers) optimizing fuel and spark is pretty easy to do for the narrow range of use of a race car, that's why the gains are not due to aftermarket ecu's, but with with the other changes like valves and port size as well as cams. (see Dennis' engine results) their optimization of fuel and air mixtures and timing resulted in only about 15hp.
well, proof will be on this engine wont it!???
Looks great Brian!
Mark
Old 07-04-2013, 03:16 AM
mark kibort
if you can get to 12.5 from 5000 to 6400, how much more can you improve power. if you can advance or retard the timing to a good range, what gains can the aftermarket system provide. sure, on the S4, there is no way to adjust the timing, but fuel you can get in a good range with the fuel regs.
I think joe and mark got 520rwhp with the stock ecu stuff!
Originally Posted by danglerb
Sounds very optimistic, is this with stock Euro S parts except for the slight shave on the heads?
Normal for 5.0L Euro is about 290 rwhp isn't it with a good exhaust etc. Given the stock brain can tune AFR and timing to pretty much whatever you want, why the assumption a different brain will result in any gain whatsoever? Its not going to change the air flow through the motor.
Old 07-04-2013, 06:38 AM
Landseer
Landseer's Avatar
How complicated is building the hydrid engine, 5.0 block with 16V USA or Euro heads?
What is involved? Is it plug / play or are we talking about engine artisan / machinest work?
Old 07-04-2013, 10:35 AM
Ducman82
Ducman82's Avatar
you have to have the pistons cut for the bigger 16v valves.... other than that, ..... thats it
Old 07-04-2013, 11:46 AM
Dave928S
Dave928S's Avatar
You can but it will work without a fly cut of the pistons ... it just makes it definitely an interference motor. There is a euro 5 litre hybrid here which has no cuts, which I've visually confirmed with an endoscope, and done front end work on to confirm it's interference. It uses standard head gaskets, is a DD and has been tracked.
Old 07-04-2013, 11:56 AM
Ducman82
Ducman82's Avatar
^^ neat! that i did not know.... could have saved me a few bucks if i had known that
Old 07-04-2013, 12:24 PM
Dave928S
Dave928S's Avatar
I was astounded when I looked at the top of those pistons, but that combination of euro top end and 5.0 litre bottom works and can handle a flogging ... I've always wondered how close the valves get though.
BTW .. I never tire of looking at your avatar ...
Old 07-04-2013, 03:02 PM
Landseer
Landseer's Avatar
I've got a Euro that needs rings and a spare 86.5 engine.
Maybe a winter project in-the-making.
Titans of the Aeroman-class avatar, you guys are. Exceptional.
T-Rex, Tasmania. Both can take me to a special place.
Old 07-04-2013, 03:20 PM
mark kibort
this is right. pistons don't hit the valves with or with out valve reliefs during normal operation. with the proper euro 85 shallow cuts, the pistons hit the valves at a valve depression of .3" (cam lift is near .45") but this means that the piston has to be at TDC to hit, and if the belt is attached , this never happens unless the belt breaks. the cut outs are only .18" deep, so its only a little safety margin and allows for movement of the cams and crank when belt is not attached.
that's pretty easy to do at a machine shop. I have the dimensions. they alsways seem to get it a little wrong, so I always go in and dremel the smillie faces a little wider to make sure the valves don't hit. (by 1mm usually)
Hmmm, kind of a loaded question as there are different levels of the build. I did the complete euro 5 liter conversion on an Ljet .
pistosn flycut
euro intake mods to adapt to US cold start and microswitches
RRFR
hogging out US Ljet "U" adapter for diameter matching for euro throttle body.
Old 12-06-2015, 12:48 AM
granprixweiss928
granprixweiss928's Avatar
is Valley Balancing still the place to go?
Old 12-06-2015, 02:02 AM
RFJ
RFJ's Avatar
Originally Posted by IcemanG17
it was a very light shave.....only one thousandth..... With a standard headgasket and the piston cuts it should be right at 11-1.....for the 5.0L euro....this engine will be ran by a full stand alone system VEMS tuned by Colin.... I am optimistic it will be 340whp-torque
That can't be just one tho more like 10 thou and John Speak has an after market chip that should add a goodly amount of power with headers.
Old 12-06-2015, 06:26 PM
mark kibort
you can use the machine shop /engine builder in MtView that ive used for many years on all sorts of projects.....Devek used these guys in the beginning.
great for work on any of the 928 components. heads, block (bore refresh or added bore)
Old 12-06-2015, 07:29 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
This is the first time I heard of exhaust valves bending from overheating. Also a first tonhear a 1 thou skimming that removes pitting. I don't think it's even possible to skim a head that little.
Quick Reply: 16V euro heads....before-after pics
