928 Forum 1978-1995
Sponsored by: 928 Specialists
So I bought a track car. Well, okay, two track cars.
Old 01-16-2013, 01:16 AM
  #61
IcemanG17
IcemanG17's Avatar
Originally Posted by GregBBRD
I think you guys just want Rob to suffer as much at home as you do.
These things take time. "Significant others" need to be slowly "conditioned" to crazy toys.
It's way easier to "sell" a dual purpose car, at home, than a dedicated race car.
Then one day, when you get home really late, from waiting at the track for a tow truck to drag your broken "dual purpose vehicle" home, it can be your "significant other's" idea for you to get a trailer!
Way less pain. Uses up way less "husband" points.
Doc is a very WISE man...who clearly has been married for a long time
I am lucky that my wife hates all of my hobbies.....regardless of what they were...... In her view they consume two things she would rather have
1: my time
2: HER money
I have yet to get her to the track......not once...ever.....I might be able to convince her to go to laguna seca, since she can go shopping with Mrs Petty while we play on the track......
my ultimate goal.......is get her on track...knowing how driven and competitive she is.....she would LOVE it.....
Old 01-16-2013, 01:49 AM
  #62
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,556 Likes on 1,235 Posts
Just for grins, here's the compilation of all of the dyno runs that (as far as I can tell) belong to the White Zombie. The first group of runs had no dates on them but clearly they're an early iteration of the stroker. One can tell where the CARB(on fiber) intake was added....
Code:
Date	Notes	Max HP	Max Tq
Early	Mark's 928 MSDS with borla (baseline)	382.3	405.9
Early	Mark's 928 MSDS with borla (baseline)	389.9	400.89
Early	Mark's 928 MSDS with borla (baseline)	392.3	412.5
Early	Mark's 928 MSDS with borla  - with air cleaner (final)	390.3	414.1
Early	Mark's 928 MSDS with borla  no aircleaner	395.9	396.3
Early	Mark's 928 MSDS with borla  -3" duals	399.8	434.6
Early	race header with dual 3"	369.1	383
Early	race header with dual 3"   #30 With Auger	380.8	388.4
Early	race header with dual 3"   #30 with  Auger	377	383.3
Early	race header with dual 3" with Auger	357.2	409
Early	race header with dual 3"	380.7	415.9
Early	race header with dual 3"	386.8	402
Early	Mark's 928 GTS	382.4	395.6
Early	Mark's 928 GTS	381.5	391.2
Early	Mark's 928 GTS	378.6	393.8
Early	Mark's 928 GTS - 3.5" flowmasters, MSDS header	391.1	398.6
7/27/2001	DASTEK	408.8	376
7/27/2001	DASTEK	412.9	401.8
7/27/2001	Stock EZK reduced fuel pressure after run #7	414.2	409.5
7/27/2001	Stock 3.0 bar Bl Pot original FBOX	407.6	460.4
7/27/2001	Dynojet 248C	399.1	403.2
3/21/2002	extrude honed intake with 80 mm TB	405.2	400.4
3/21/2002	extrude honed intake with 80 mm TB	401.2	410.6
3/21/2002	extrude honed intake with 80 mm TB	430.4	426.1
3/21/2002	extrude honed intake with 80 mm TB	438.8	420.4
5/6/2002	extrude honed intake with 80 mm TB, kelly moss heads	354.5	403.7
5/6/2002	extrude honed intake with 80 mm TB, kelly moss heads, stock EZK	406	424.9
5/6/2002	extrude honed intake with 80 mm TB, kelly moss heads	413.1	432.3
7/29/2002	extrude honed intake with 80 mm TB, kelly moss heads, stock EZK	416	427.3
7/29/2002	extrude honed intake with 80 mm TB, kelly moss heads, stock EZK	407.7	407.9
7/29/2002	extrude honed intake with 80 mm TB, kelly moss heads, stock EZK	405
9/6/2002	Baseline	422.3	392.5
9/16/2002	Tri-Y header without muffler, 5" of vacuum, 30 psi fuel	417.9	429.6
9/16/2002	Tri-Y header without muffler, 3" of vacuum, 42 psi fuel	406.2	435.2
9/16/2002	Tri-Y header without muffler, 3" of vacuum, 42 psi fuel	402.2	435.2
9/17/2002	Stock ECU, Stock intake, Stock exhaust	349.7	372.4
9/17/2002	Tri-Y header without muffler, 5" of vacuum, 30 psi fuel	431.4	443.2
10/2/2002	Tri-Y header without muffler, 5" of vacuum, 30 psi fuel	431.2	444.3
10/3/2002	Stock EZK, stock intake, no cat/magnaflow	381	379.7
10/3/2002	Stock EZK, stock intake, cat, stock exhaust	342.2	368.7
6/30/2003	CARB and INT 36 LB injector  (This dyno chart in 928 Forum V2 #1)	484.2	437.5
7/17/2003	CARB and INT 36 LB injector, with DASTEK	474	443.2
7/17/2003	CARB and INT 36 LB injector, with DASTEK	469.1	445.3
7/30/2003	CARB and INT 36 LB injector, with DASTEK	486	451.7
10/16/2003	Equal legth headers, CF manifold	511.9	442.5
10/16/2003	Equal legth headers, CF manifold	506.5	432.1
11/24/2003	CARB and INT 36 LB injector, with DASTEK	473.5	437.8
11/24/2003	Equal length headers, CF manifold	507.9	462.7
11/25/2003	CARB and INT 36 LB injector, with DASTEK	471.5	447.1
11/25/2003	CARB and INT 36 LB injector, with DASTEK	474	438.6
11/24/2003	Equal length headers, CF manifold	517
8/26/2004	Equal length headers, CF manifold	481.3	434.8
8/17/2005	CARB and INT new injectors 36 LB injector, with DASTEK-stock exhuast	436.1	401.7
9/23/2005	CARB and INT new injectors 36 LB injector, with DASTEK	496.6
9/23/2005	CARB and INT new injectors 36 LB injector, with DASTEK	478.2	438.3
12/13/2005	CARB and INT new injectors 36 LB injector, with DASTEK	474	440.3
12/13/2005	CARB and INT new injectors 36 LB injector, with DASTEK	475.8
12/13/2005	CARB and INT new injectors 36 LB injector, with DASTEK	476.9
12/31/2005	CARB and INT new injectors 36 LB injector, with DASTEK	475.8
8/24/2007	Carb and Int. new injectors 36 lb injector with DASTEK. New engine, Hall sensor and knock sensors disconnected	413.9	369.4
8/26/2007	Carb and Int. new injectors 36 lb injector with DASTEK. New engine, Hall sensor and knock sensors disconnected	518.1	451.7
9/27/2007		488.5	399.51
9/27/2007		496.2	419.27
9/27/2007		508.42	429.58
9/27/2007		472.2	429.27
8/14/2008	Equal length headers, CF manifold	496.1	431.6
Old 01-16-2013, 02:10 AM
  #63
RED SHARK 1990
RED SHARK 1990's Avatar
Default carbon naca duct hood
Hello Rob, i am taking the hood off to put back to stock and therefore asking you if you want my old hood. With minor body work ,this hood would cool your engine alot better! front bumper too if needed.
Old 01-16-2013, 02:37 AM
  #64
Rob Edwards
Archive Gatekeeper
Appreciate the offer, Luan, but I think the canisters for the Motons are mounted about where your NACA ducts are located. Besides, Mark's hood already has been lightened, and it used to be cut for a CAI at the base of the windshield, in the era before the carbon fiber intake. He also has these bitchin' hood pins holding it down (installed sometime between 7/21/00 and 9-3-00, judging by the picture record), that I'd have to remove to fit a different hood. Check out his special asymmetrically lightened hood hinges- Mark said he spent a ton of time drilling this out and discovered that it bought him way too little weight savings, so he didn't bother with the other side.
Old 01-16-2013, 11:37 AM
  #65
RED SHARK 1990
Hi Rob, you should take it and see if it works or not. I am not doing anything with it.....
Old 01-16-2013, 09:10 PM
  #66
BC
BC's Avatar
Originally Posted by Rob Edwards
Mark was there, on a Sunday night at 928Intl, when she arrived way after dark to pick me up, he's still in counseling after having seen the look on her face.
Oh man, this is priceless, lol. Awesome.
Old 01-16-2013, 10:12 PM
  #67
dr bob
Chronic Tool Dropper
dr bob's Avatar
Two ways to hell with SO's and race cars. Most common is that she's not involved at all and she doesn't understand. Or she's totally involved and has her own helmet.
Old 01-17-2013, 03:04 AM
  #68
justaguy
justaguy's Avatar
I'm very glad to read this.
Sad to hear Mark has decided to stop racing, But very glad to hear Rob will continue the torch and the car will remain on track.
I'll second what Brian has offered. My car is at the track and you're welcome to it.
May be we could talk Mark into doing a private school for all us 928 guys at T-hill?
Any ways, cogratulations I'm glad you have the car.
Old 01-17-2013, 03:18 AM
  #69
Rob Edwards
Archive Gatekeeper
That would be way cool! If Mark can give Hurley Haywood pointers, he ought to be able to help us too....
Old 01-17-2013, 03:32 AM
  #70
Mark Anderson
The Parts Whisperer
Mark Anderson's Avatar
I can assure you I have no Hurley pointers but I am happy to share any and all info and experience I have to offer
Old 01-17-2013, 05:24 AM
  #71
danglerb
danglerb's Avatar
Wow. Thinking some more about it, wow.
Listen to Jim, seat time soonest is best, plus you get to visit your family with no finish the car deadlines.
Old 01-17-2013, 02:04 PM
  #72
IcemanG17
IcemanG17's Avatar
Dr Rob is at the "golden" stage of DE-racing...... Having a drive to track and home racer is the most cost effective way to start......
I would seriously consider starting on street tires as well....they last MUCH longer and still perform pretty good...... Of course there is enough room to bring a full set of r comps to switch at the track....
Spend your track days learning......plenty of great instructors down there....you will be racing soon enough!!!
Old 01-17-2013, 03:21 PM
  #73
Rob Edwards
Archive Gatekeeper
Absolutely the plan is to start on DOT's, I've done enough Skippy courses to know that my hands (and brain) aren't fast enough to get myself out of trouble on slicks, they're something to work up to. For me this is all about 1) having fun, and 2) working up to not sucking at driving, as I will never fit in my sponsored F1 ride no matter how big a seat they make.
Old 01-17-2013, 06:16 PM
  #74
Paul Dortkamp
Paul Dortkamp's Avatar
Hey Rob, congratulations, the best way to go. Much easier to dial a car down than up. When I bought my track car the suspension set was set up with very stiff springs and dampers. I could barely drive it, so swapped in a more mild setup and ran with R spec tyres. A couple of years later now, with much more experience, I am thinking going back up. My track car has cheap Historic rego in NSW (> 30 years old) and so I can drive it to and from the track. The occasional trip home on a tilt tray about one a year, is not much of an inconvenience.
Old 01-17-2013, 06:25 PM
  #75
Mark Anderson
The Parts Whisperer
Originally Posted by Paul Dortkamp
A couple of years later now, with much more experience, I am thinking going back up. M.
I have tried spring rates all over the map (some as high as 1600 lbs) What I finally setteled on was a very soft spring rate of 800 fronts and 350 rears. That said I have made some modifications to the shock attachment points which did alter spring wheel rate, but not that great. You also need to remember that my car is nearly 1000 lbs lighter than stock.
Quick Reply: So I bought a track car. Well, okay, two track cars.
