928 Forum 1978-1995
Sponsored by: 928 Specialists
Flush center console conversion design input
Old 02-28-2013, 12:28 PM
  #46
BigAl1
BigAl1's Avatar
The 2 gauge hole knock-outs are 2.066" dia to fit standard 2 1/16" gauges - do you have gauges that need 2.125" holes?
I'll be trimming mine with 3M vinyl in brushed aluminum to match the Momo steering wheel center and other details inside.
Old 02-28-2013, 12:30 PM
  #47
xschop
xschop's Avatar
Your gauges look just like the Red-Digital Glow-Shift Gauges I'll be using. Put me down for a unit.
What diameter is your shift lever? I'll be machining my own billet shift lever and I'm thinking only 1.50" diameter cylindrical shape.
Old 02-28-2013, 01:08 PM
  #48
BigAl1
BigAl1's Avatar
Gauges pictured are Ducman's, and I will have a WBO2 gauge in my left position. My shift **** is a little under 2"dia.
Old 02-28-2013, 01:38 PM
  #49
Alan
Electron Wrangler
Alan's Avatar
Originally Posted by BigAl1
...The power port knock-out is on the RH side, and will clear the auto shifter nicely.
For an Auto yes - for a manual probably not.
Even for an auto it does depend a lot on what you plug in - some of these things are shaped like mushrooms!
I have recently moved my power outlets (one 12v and a dual USB) to the passenger side of the console for this reason.
Alan
Old 06-02-2013, 12:29 PM
  #50
Ducman82
Ducman82's Avatar
For us manual/vac operated head unit guys, I solved the hot/cold cable issue. Bicycle cable! You can bend that stuff and any angle and it slides perfect! I was so happy I forgot to take pictures....
Old 06-24-2013, 12:51 AM
  #51
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Very interested in this now.
Will the dash panel support the new alpine 8" screen?
it is a standard DoubleDin chassis.
Chassis Size (W x H x D) mm: 178mm x 100mm x 165mm
Chassis Size (W x H x D) in: 7'' x 3-15/16'' x 6-1/2''
Old 06-24-2013, 10:46 AM
  #52
Ducman82
Ducman82's Avatar
thats the same size dimensions as mine. will fit fine.
Old 06-24-2013, 12:42 PM
  #53
Speedtoys
Speedtoys's Avatar
Im more curious about the screen area outside of the mounting hole itself.
Old 06-24-2013, 01:32 PM
  #54
Ducman82
Ducman82's Avatar
Picture of the unit?
Old 06-24-2013, 01:51 PM
  #55
Speedtoys
Speedtoys's Avatar
http://www.alpine-usa.com/product/view/ine-z928hd
Old 06-24-2013, 02:13 PM
  #56
Ducman82
Ducman82's Avatar
Hummmm ya, that might be tricky. no nose dimensions... TBD... ugh...
Old 06-24-2013, 02:26 PM
  #57
Speedtoys
Speedtoys's Avatar
Thats why Im wondering what the corner to corner area usable is with this kit. The length of the white line here, what's that length?
Old 06-24-2013, 02:53 PM
  #58
Ducman82
Ducman82's Avatar
from that white line (outside of trim to outside of trim) is about 8.75inches. i am just wondering if the "unit" the part that fits in the cage is the same. i have the alpine INA-w900bt.
that bottom lip of the other alpine unit, if it is not over an inch, should fit just fine.
Old 07-02-2013, 03:31 PM
  #59
Koenig-Specials 928
Koenig-Specials 928's Avatar
Here a picture of a rough install I made 2 months ago. With less than half a day's work I could get it to fit perfect.
Old 07-03-2013, 09:08 AM
  #60
BigAl1
BigAl1's Avatar
Sorry I've been out of the loop for the last few months! Been renovating a house so my focus is elsewhere. Looks good Fred!
Quick Reply: Flush center console conversion design input
