NOS parts just arrived
The Parts Whisperer
We just got in a shipment of new old stock from a Porsche dealer. There are some interesting items like new Euro S pistons and new late water pumps
qty part # description
1 928 101 000 00 seal kit
1 928 102 111 02 pilot bearing
12 928 103 086 10 piston
8 928 103 088 10 piston
8 928 104 116 00 cam cover
1 928 104 117 01 socket screw
4 928 105 139 02 camshaft spacer
5 928 105 215 00 cyl. Head plug
81 928 105 413 00 intake valve $10 ea
150 928 105 417 03 ex. valve $10 ea
10 928 105 468 01 valve spring seat
13 928 105 468 03 valve spring seat
20 928 105 470 01 valve spring seat
15 928 105 470 03 valve spring seat
1 928 105 551 00 tensioner push rod
1 928 105 571 00 tensioner roller
16 928 105 903 00 valve spring set
2 928 106 015 22 water pump
1 928 106 110 04 cooling fan support
1 928 106 129 17 thermostat
1 928 106 163 00 seal ring
1 928 106 173 02 thermostat housing
3 928 106 197 03 regulator gasket
1 928 106 257 03 radiator cap
2 928 107 081 00 piston
1 928 107 707 03 oil setarator gasket
1 928 110 149 00 fuel line clip
1 928 110 173 00 vacuum limit valve
1 928 110 173 01 vacuum limit valve
1 928 110 185 03 air filter
1 928 110 198 02 regulator
1 928 110 255 00 fuel injector
1 928 110 271 02 fuel line clip
1 928 110 439 00 air distributor
10 928 110 694 01 air manifold seal
1 928 110 920 01 press. Regulator kit
1 928 111 955 00 sleeve
1 928 113 017 X rebuilt air pump
1 928 116 031 03 pressure plate
1 928 116 033 03 pressure plate
1 928 116 033 26 pressure plate
2 928 116 075 01 clutch knuckle pivot
1 928 116 085 08 t/o bearing
1 928 116 237 20 clutch slave
1 928 201 083 02 shut off valve
1 928 201 187 02 fuel filter seal
4 928 301 111 00 o ring
3 928 301 395 03 trans covre gasket
1 928 302 290 05 shim 1.4
6 928 302 298 10 shim .1
2 928 302 298 11 shim .15
2 928 302 298 12 shim .2
1 928 302 318 02 brake band
1 928 302 321 00 anchor block
1 928 302 322 00 anchor block
1 928 304 211 05 synchro
1 928 304 211 23 synchro ring
3 928 331 588 10 rubber mount
8 928 332 029 01 cv joint
4 928 332 033 10 axle
1 928 332 097 00 flange
7 928 332 215 02 diff. oil seal
8 928 332 219 00 diff. adj. washer .1mm
2 928 332 219 01 diff. adj. washer .2mm
2 928 332 219 02 diff. adj. washer .25mm
2 928 332 219 03 diff. adj. washer .5mm
2 928 332 219 04 diff. adj. washer 1.0mm
2 928 332 279 01 diff. disc
22 928 332 285 00 diff lock plate
2 928 332 555 00 spring
2 928 332 922 01 cv boot kit
2 928 332 924 01 cv boot kit
4 928 332 924 02 cv boot kit
1 928 341 049 12 ball joint
2 928 341 466 00 eccentric
2 928 347 332 02 tie rod end
4 928 347 329 04 tie rod stop
1 928 347 445 00 power steering hose
1 928 347 755 02 ignition cam
4 928 347 927 00 fluid reservior seal
1 928 351 043 01 front brake disc
2 928 351 931 00 brake pad
2 928 351 937 00 safety eye
1 928 352 823 00 guide plate
4 928 352 952 00 rear brake pad
4 928 356 555 00 clip
1 928 423 193 00 clutch master
1 928 423 197 01 clutch line
1 928 423 199 01 clutch line
1 928 423 210 03 pedal pad
1 928 423 211 00 pedal pad
1 928 423 221 01 clutch hose support
1 928 423 542 00 bushing
1 928 424 255 12 press. Rod
1 928 424 405 01 guide tube
5 928 437 921 00 seal kit
1 928 504 345 02 spring
2 928 505 325 04 insignia
1 928 505 335 05 decal
1 928 511 143 02 cable housing
1 928 511 175 02 release handle
2 928 512 331 05 rear hood stay
1 928 521 818 03 drive gear
2 928 521 818 04 drive gear
1 928 522 415 03 seat belt rose
1 928 528 181 02 cover
2 928 528 183 03 washer tank cap
2 928 537 111 03 rod
1 928 537 302 05 cover
4 928 537 341 02 buffer
4 928 537 342 02 window vib.
1 928 551 087 03 strap
1 928 555 075 02 coin box
3 928 555 275 02 seat belt rose
2 928 555 355 02 roof lining cover
1 928 559 213 03 clip
4 928 559 281 02 side moulding sleeve
1 928 564 081 02 sunroof latch spring
1 928 570 423 00 clip
1 928 573 123 02 expansion valve
1 928 574 040 02 vent frame
1 928 574 072 02 flap
2 928 574 093 03 button
10 928 574 498 03 spring
1 928 602 032 03 distributor
1 928 602 033 00 distributor
1 928 602 103 00 gasket
4 928 602 311 00 spark plug connector
1 928 602 503 00 coil
4 928 602 541 00 distributor belt
6 928 602 557 01 wire end connector
1 928 602 702 02X switch unit
1 928 602 913 00 dist dist cap
1 928 603 114 00X rebuilt alternator
1 928 603 114 01X rebuilt alternator
1 928 603 904 00 fan mounting set
1 928 604 121 00 insulator
2 928 605 101 00 temp switch
1 928 606 121 02 air flow meter (used)
1 928 606 124 00 o2 sensor
1 928 606 126 00 temp sensor
1 928 606 128 01 o2 sensor
1 928 608 013 00 fuel pump
1 928 608 104 02 fuel pump
2 928 609 105 03 spark plug connector
1 928 610 511 00 carrier
2 928 618 311 03 contact
9 928 612 313 00 contact
1 928 612 313 01 contact
1 928 612 423 00 elect. Socket
1 928 612 515 02 elec. Connector
1 928 612 615 00 elect. Plug
1 928 612 865 02 buffer
1 928 612 869 00 pos. post cover
1 928 612 871 02 cover
1 928 612 930 00 lock harness
1 928 613 049 00 switch
1 928 613 144 00 seat switch
1 928 613 173 00 alarm contact
1 928 613 181 00 saeat switch
1 928 613 241 00 switch
1 928 615 113 01 relay
2 928 615 117 00 relay
1 928 615 117 02 signal relay
1 928 618 105 00 relay
1 928 618 123 02 control unit
1 928 624 211 00 locking element
1 928 628 077 00 washer nozzle
4 928 628 621 00 wiper arm cover
5 928 628 622 00 wiper arm cover
4 928 628 623 00 wiper arm cover
4 928 628 623 01 wiper arm cover
1 928 631 412 02 side marker
1 928 631 927 00 lens
1 928 631 937 00 lens
2 928 641 943 02 fuel/temp indicator
1 928 641 963 03 928 voltmeter
2 928 641 94 00 elect. Connector
1 928 645 030 00 antenna
1 928 701 050 03 license bracket
2 928 803 141 00 seat belt cover
2 928 803 143 00 seat belt clip
The Parts Whisperer
Addict extrordinare
928 116 085 08, how much for the TO bearing?
928 101 000 00, what is this seal kit for? (I'm PET challenged right now)
928 110 185 03, is this the orange banded air filter?
928 602 503 00, how much for the coil?
928 608 013 00 how much for the fuel pump?
928 615 113 01 how much for the fuel pump relay?
928 631 927 00 how much for the lens?
928 645 030 00, how much for the antenna?
Feel free to post here, email, or PM. Good stuff! Thanks Mark!
Mark,
My PET isn't cooperating with the part number listed, but if this is what I think it is, I want it.
Goes on the driver's door...right?
What might be the price?
Thanks!
Thanks!
The Parts Whisperer
The Parts Whisperer
